Author Topic: what MPG do you get?  (Read 5492 times)
« on: August 23, 2010 - 09:45:21 PM »
Last weekend I did just over a 200 plus mile trip in the Challenger.( Mopar car show) My fuel gauge is on the Fritz so I stopped about every 2 hours to fill up so I didn't run out. This was my first long trip with the car and I was pleasantly surprised! Every time I stopped it took way less to fill it than I figured! I overfilled it a few times as I didn't believe it was full when the pump clicked off! :grinno: Most of the time I was 60 MPH at about 3000RPM'S on the tach.
When I got home and figured out the mileage I was shocked to see it got almost 14 MPG! :faint: I figured that was pretty good for a 440?
I'm running a mild 440/727 with 3:55 rear gears, 850CFM carb
Just curious what others get and with what combo?
Offline TreeFrog
    • TreeFrog
Re: what MPG do you get?
« Reply #1 on: August 23, 2010 - 09:53:22 PM »
real gas or ethanol?
hi/lo/med grade?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
« Reply #2 on: August 23, 2010 - 10:03:21 PM »
hi/lo/med grade?
If your asking about me? I used 91 octane.( med grade)
« Reply #3 on: August 23, 2010 - 10:11:19 PM »
I get about 10mpg, but I drive it hard for enjoyment, not mpg.  :bigsmile:
Offline JayBee
« Reply #4 on: August 24, 2010 - 08:22:45 AM »
Check out this link
http://www.cuda-challenger.com/cc/index.php?topic=65886.0
Brad, if that's MP(Cdn)G divide by 1.2 to get 11.7 MP(US)gallon
« Last Edit: August 24, 2010 - 08:27:11 AM by JayBee »
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #5 on: August 24, 2010 - 08:30:45 AM »
Check out this link
Thanks! missed that one!
« Reply #6 on: August 24, 2010 - 10:28:30 AM »
I have seen #S much higher than that , occaisionally over 20 MPG with a 440 & 3.23 gears
we did a 512 stroker with the 833 OD & averaged 17.7 mpg with a 950 carb
Offline Oldschool
  • Member Since 9-05-06
« Reply #7 on: August 24, 2010 - 10:33:04 AM »
I am getting about 10 on the road driving easy.  I think it goes into negative numbers when I get after it hard....    :smilielol:
Ken  --  In Georgia
Offline TreeFrog
    • TreeFrog
« Reply #8 on: August 24, 2010 - 10:43:39 AM »
hard to tell if the tack Speed-O or Gas gauge moves faster....
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #9 on: August 24, 2010 - 10:54:31 AM »
I'm right there with you Oldschool. When I drove to Carlisle, I got a steady 10 MPG on the highway with 3:91 gears and 543 cubes, naturally aspirated, 1,000 cfm Pro-systems carb. I imagine under heavy throttle, I could watch the gas gage lower itself and the MPG's would be in the negative!! :smilielol: :roflsmiley: :smilielol:
                                                      Matt B.
Matt
Offline Killer_Mopar
« Reply #10 on: August 24, 2010 - 12:01:03 PM »
Mild 451, 833OD, 3.55 gears, 27" tall tire
When I went down to the Nats I was getting around 15 on the highway doing mostly 75 mph (my dad was in front of me and he has a lead foot). I would imagine somewhere between 18-20 mpg at 60-65 mph.
Offline tommyg29
« Reply #11 on: August 24, 2010 - 01:01:59 PM »
440 6 bbl here on 93 octane and I get about 6mpg, and not much better than that on the highway.
I also run well over 3000 rpm at 70 mph...cant hear yourself think.
Its running very rich so that prob  has something to do with it, but Ive heard similar numbers from other 6bbl guys.
« Reply #12 on: August 24, 2010 - 05:59:07 PM »
I bnet that could be tuned to run far better , more timing , possibly a lower Power valve depending on vacuum etc
« Reply #13 on: August 24, 2010 - 06:30:29 PM »
Brad,
  You cheated using Canadian gallons.   :poopoke:
Still, that isn't bad at all with 3:55's. Is your engine basically stock, or has it been hopped up some?
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #14 on: August 24, 2010 - 07:07:26 PM »
never enough mpg,
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
