Noob tranny cooler question - what connectors?
Author Topic: Noob tranny cooler question - what connectors?  (Read 3465 times)
Offline Aloid
  • Simi Valley, CA
« on: August 28, 2010 - 04:06:40 AM »
I'm replacing my aftermarket radiator that doesn't fit the car with one that does.  The new one has a tranny oil cooler with threaded connector (bung?).
My oil lines don't have the fitting needed to connect to the cooler bung.   It's dang hard to search the internet when you don't know what the fittings are called...
The existing oil lines go to a separate oil cooler which just uses circle (?) clamps and rubber hose to connect to the steel line.  I want to remove that cooler to clean up the car.
The shop manual shows the fittings and they look like something I can get at a plumbing store (maybe Autozone?)...  the radiator is a champion EC374.
Please enlighten this lowly noob.
Alan
'73    (O[   ]||||[   ]O)
////  NAME CHANGED TO 360FISH  \\\\
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Noob tranny cooler question - what connectors?
« Reply #1 on: August 28, 2010 - 06:25:29 AM »
You will need to use flare fittings going from the tubing to the radiator available at your local auto parts or hardware store.If your transmission line ends have been cut off for hoses to attach you will need to flare the end with a flaring tool(don`t forget to put the fitting on FIRST!) if they are still long enough to work.Your other options are buying a roll of tubing and making new lines or buying them pre-made from a resto parts co.
http://www.jacksautoparts.com/catalog/transmission.html
« Last Edit: August 28, 2010 - 06:27:05 AM by torredcuda »
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Aloid
  • Simi Valley, CA
« Reply #2 on: September 01, 2010 - 02:08:44 AM »
Ended up at Pep Boys and they had what I needed...
I installed the Champion 26" rad and hooked it all up.  First test was great.
I still have to install a longer overflow hose and put in the clutch fan...
Hopefully soon my overheating problems will go away.   :cheers:
'73    (O[   ]||||[   ]O)
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: September 01, 2010 - 10:15:45 AM »
Looks nice... :)  don't forget the shroud
Offline mopar12372
    • mopartech
« Reply #4 on: September 02, 2010 - 12:58:07 AM »
w :thumbsup:
RESTO PICTURES
Offline Aloid
  • Simi Valley, CA
« Reply #5 on: September 02, 2010 - 02:21:00 AM »
There are some nice chromed universal shrouds... may go that route.
Cheap and available...   :drunk:
'73    (O[   ]||||[   ]O)
Offline Aloid
  • Simi Valley, CA
« Reply #6 on: September 03, 2010 - 02:24:38 AM »
okay, the fan is in... finally.  Those bolts were a royal pain!  But patience is a virtue (or so I'm told).   :hyper:
I've got an offset from the radiator to the clutch of 1.5 inches from the top to 1.25 inches to the bottom...
Everything is snug and ready to be fired up tomorrow.  Then it's time to look for that shroud and then some coooool sailing!   :aarg:
'73    (O[   ]||||[   ]O)
Offline mopar12372
    • mopartech
« Reply #7 on: September 03, 2010 - 09:00:15 PM »
looks good , where did you find the fan assemblie?
RESTO PICTURES
Offline Aloid
  • Simi Valley, CA
« Reply #8 on: September 04, 2010 - 02:48:20 AM »
Thanks Bill...  The Fan clutch is a Hayden from Pep-Boys and the fan is from Auto-Zone...  I also have a Napa and an O'Reily's (was Kragen) here in Simi Vally...
The shroud will come from Amazon... it's much cheaper there than from anyone else...  (Trans-Dapt 9454 Fan Shroud 5.5" Wide )
I gave it a short test this evening and had good air flow though the radiator already...  a good start.
Hope you're getting time to work on your car.  Want to see it on the road!
Alan
'73    (O[   ]||||[   ]O)
Offline mopar12372
    • mopartech
« Reply #9 on: September 04, 2010 - 12:38:01 PM »
yea im trying to get the cuda going , tomorrow i finish up the welding (done ) . it will appear to be a 1970 ,hahaha .have any part #s?
for now im spending very little on the car and just repairing and installing what i have to get it on the road . close very close
RESTO PICTURES
Offline Aloid
  • Simi Valley, CA
« Reply #10 on: October 06, 2010 - 02:47:35 AM »
I finally put the finishing touches on the cooling system.  The new balanced thermostat (the copper one) was installed and the shroud went on.  Took the ‘Cuda out on a 40 minute shake down on a hot day and everything went great… at least until I was heading home and noticed some whisps of steam coming out of the front.  Looked like I have some water(?) coming out (collecting on) the top of the valve cover breather?  Seems odd… it evaporated quickly and I’ll have to run it again to confirm.
Hope these pics are not too large for everyone...
Old vs new (on the right)
Parts is parts…
After the surgery was completed…
With the shroud on
Shiney bits…
Alan
« Last Edit: October 06, 2010 - 02:49:44 AM by Aloid »
'73    (O[   ]||||[   ]O)
Offline mopar12372
    • mopartech
« Reply #11 on: October 08, 2010 - 01:02:17 AM »
exactly what area was the water comming from/?
RESTO PICTURES
