Author Topic: Vibration - help me please!!! - Update, Fixed!  (Read 3969 times)
Offline CUDA JAS
  • vroooooom!
« on: August 28, 2010 - 09:48:45 PM »
My cuda has developed a vibration ...I would describe it as an oscillating vibration that starts at 50mph and get progressivly worse the faster you go.
It feels like it is comming from the trans area / between the seats.
The vibration is not present when you pop it into neutral as you are going down the road and rev the engine.
Any suggestions on what it could be.
I have made the following changes over that last few weeks...new trans mount, new OEM engine mounts (replaced incorrect mounts and moved the engine forward a fair bit) and a new exhaust system (headers back).
The vibration was not present prior to these changes.
Helppppp, I was hoping to take my car out of town tomorrow, but now I am not sure I should!!!!
Thanks,
Jason
« Last Edit: September 07, 2010 - 04:34:50 PM by CUDA JAS »
74 'cuda 360/727
Just call me a gearhead!
Offline djwhog
Re: Vibration - help me please!!!
« Reply #1 on: August 28, 2010 - 10:45:04 PM »
Possible Driveshaft? Maybe angle is a little diff and the ujoints are worn?
I know when you take a trans out of gear the load change weather on or off the throttle will make a change?
Other than that it would seem something is maybe rubbing since you said it was not there before the work right?
However, man sometimes stuff just happens and drives ya a little nuts:)
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: August 28, 2010 - 11:50:24 PM »
Hmmm. think I found it...just went out and measured the drive shaft, 41.6/8 from center to center on the u-joints
I did some digging and I think the drive shaft should be 43.79 inches.
Any thoughts!
Jason
74 'cuda 360/727
Offline drewcrane
« Reply #3 on: August 29, 2010 - 10:38:58 AM »
Any thoughts!
Since you said you moved the engine forward quite a bit ,
look at the input shaft and see where it is in relation to the end of the trans.
,there should be a slight wear pattern on the input shaft from where it used to be and now i bet it is not going in to the trans. far enough
Jason
Offline djwhog
« Reply #4 on: August 31, 2010 - 08:23:41 PM »
Well if it is way to short angles can be a mess, but also you will not be in enough for tailshaft transmission bushing support too.
did you get her fixed yet?
« Reply #5 on: August 31, 2010 - 08:29:58 PM »
 :popcorn:
Offline CUDA JAS
  • vroooooom!
« Reply #6 on: August 31, 2010 - 10:09:37 PM »
Nope not yet...I wish though.  I pulled the old one out tonight, looks like the slip yolk is all buggered up too!
The drive shaft is definalty too short (42.5 inches).
Jason
74 'cuda 360/727
« Reply #7 on: August 31, 2010 - 10:59:03 PM »
 I wonder what the tailstock bushing looks like then? :dunno:
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: August 31, 2010 - 11:19:21 PM »
I olnly looked quickly, but I think it is OK, jeezz it better be!  Looks like someone cut down the slip yolk. :swear:
74 'cuda 360/727
« Reply #9 on: September 01, 2010 - 07:24:36 AM »
That driveshaft I offered you does have a slip yoke on it if you need it.
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: September 06, 2010 - 10:00:32 PM »
I just wanted to say thanks to the 3 members that offered me a driveshaft...it really shows how great this site is!
I found the correct shaft locally, and shoudl be up and running tomorrow...just in time to pick my daughter up from her first day at school!
Here are a few pics of what some hack shadetree mechanic cobbled together (and a proper slip yoke and drive shaft for comparison)...
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
Re: Vibration - help me please!!! - Update, Fixed!
« Reply #11 on: September 07, 2010 - 04:39:38 PM »
Hey guys...spent a couple of hours today installing the correct driveshaft (new u-joints too).
Went for test drive a little while ago and the vibtation is gone. :grinyes:
Nice to have something work finally!
Jason
74 'cuda 360/727
Offline IMNCARN82
  • LeDZeP
« Reply #12 on: September 07, 2010 - 05:46:59 PM »
That's great!!   I'm right behind you. Glad it worked out. I've got a good reference here to try for a driveshaft shop. Gonna try that before new axels and housing.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #13 on: September 07, 2010 - 06:26:57 PM »
ALRIGHT!!!! :clapping: :woo:   good for you!
« Reply #14 on: September 07, 2010 - 07:03:11 PM »
 :woo:
