Sorry NZ, I should have explained it. Go to the smilie you want, right click over the smilie or emotiocon you want and then select properties, go to the http address on the window that just opened and left click and drag across the entire address, make sure you don't miss anything on the address or it won't work. Now go to a blank word document and right click on it and select paste, you can go to your post instead if you want and paste it there but I collect a few on a document and then you don't have to go to the link to get your emotiocon. Once you have pasted the address you must put the code on the front and the end of the address for this website to recognize it as an image. Type on the end of the link
[/img] now on the front of the link type
[img]. Check it out and give it a try!
