Author Topic: seatbelts  (Read 1009 times)
Offline dixiedog
seatbelts
« on: August 30, 2010 - 09:39:22 AM »
Anybody have any pictures of the locations and belts for a 70 challenger.  I have a box of belts for mine I will have to restore or buy new ones.  I don't think they are all there.  How many belts go in the back seat (2 sets is what I am thinking).  Also I am trying to figure the shoulder belts out.  I think mine are missing.  Thanks, Danny
Offline Supercuda
Re: seatbelts
« Reply #1 on: August 30, 2010 - 10:25:03 AM »
2 belts for the back seat, with the buckles on the inners, as I recall (certainly somebody here can confirm or correct), and the fronts were set up with the buckles on the inners, and the retractor on outside, and shoulder belt separate and mounted above the door.
Offline dixiedog
Re: seatbelts
« Reply #2 on: September 01, 2010 - 09:05:47 AM »
how and where does the shoulder belt attach?  I have already had my headliner installed.  Thanks, Danny
Offline sadil340
Re: seatbelts
« Reply #3 on: September 01, 2010 - 09:48:54 AM »
 :popcorn:
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline Supercuda
Re: seatbelts
« Reply #4 on: September 01, 2010 - 10:15:09 AM »
You're supposed to locate the boss in the roof for the shoulder harness before installing the headliner, but we can work with what you've got. Feel along the roof, through the headliner, at about the rear edge of the door. You will feel a raised area, with a tapped hole in it. Make an "X" cut over the hole, and you will have the shoulder belt mount. The hanger mounts over about the middle of the door glass span, at close to the same level of the belt anchor. This will be harder to locate, and may result in you having to partially disassemble the trim and headliner at this point. More "X" cuts over the fastener holes will get you what you need, here. Look at as many cars and pictures of this installation as you can, before you do anything! This comes under the "measure twice, cut once " rule. You can save a lot of grief by going slowly and carefully on this.
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
Re: seatbelts
« Reply #5 on: September 02, 2010 - 01:45:18 AM »
Offline dixiedog
Re: seatbelts
« Reply #6 on: September 02, 2010 - 09:31:08 AM »
Thanks guys, big help.  Danny
