Author Topic: HEDMAN header fit on 440 in 71 Cuda  (Read 5550 times)
Offline DocMel
« on: August 30, 2010 - 05:23:25 PM »
Here's the real deal for those considering the $170 Hedman headers (I got mine from Summit)
First:  YES, they do fit with NO mods.  Some helpful hints:
1.  Use a two post lift.  You'll  be going from the top and the bottom of the car as you work, and back and forth
2.  Disconnect battery, remove passenger side front shock
3.  Disconnect  (auto trans) kickdown linkage swivel bracket, remove spark plugs
4.  Remove starter and factory exh manifolds.
5.  Remove front motor mount bolts
6.  Use a floor jack and jack front of motor motor up as high as it will go  (WATCH RADIATOR SHROUD WHEN YOU DO THIS!).  Install passenger side header  (Watch that you dont upset the balance while doing this if your car is also on a 2 post lift)!!
7.  Remove only the suspension componants required to get the driver header in.  (Look and use your common sense)
This is the hardest part:   It will take 2 folks:  Lay on your back and hold starter in place between the new header and the engine block, (DO NOT bolt it in yet), while you slide the header up into place and your buddy helps from the top to hold the header and also help get it into place while you slide the header from bottom to top.  You'll never get it done with the starter bolted in place.  Move the starter around while the header is being put in place.   With header NOT bolted in place yet, snug the starter down onto its mounts first when you get everything in its approximate place, then place in the header gasket and snug down header bolts.  This procedure is a ***** trying to manhandle the heavy starter around while getting the header in place, but it only took about 5 minutes to get the header in place using my technique
Put everything back in place.  Wipe headers down with degreaser.  Heat up engine BRIEFLY a few times to set the factory paint on the headers  (It will still blister though in some places)
Drive and retourque header bolts a couple of times after the first few times driving
I have a 71 Cuda, Auto, PS, and the above worked for me with NO mods to the headers
Offline ntstlgl1970
  • T a c o c a t
Re: HEDMAN header fit on 440 in 71 Cuda
« Reply #1 on: August 30, 2010 - 06:37:43 PM »
Are these full length or shortys?
« Reply #2 on: August 30, 2010 - 06:57:57 PM »
I found they didn't fit so well at all!
http://www.cuda-challenger.com/cc/index.php?topic=55942.0
« Reply #3 on: August 31, 2010 - 08:29:43 AM »
I have yet to see a set of hedmans fit
Offline Canadian Cuda
« Reply #4 on: August 31, 2010 - 03:55:49 PM »
 :popcorn:
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #5 on: August 31, 2010 - 05:30:14 PM »
Any pictures of them installed from above on each side, plus how far they hang down?
1996 Dodge Viper GTS Coupe
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #6 on: August 31, 2010 - 05:46:48 PM »
I think it depends on what number your getting. the 78036 i put these on our 440+6 car NO fitment issues. real close to the gear. Put same set on my buddies 383 chall and only issue was clearance for the mini starter that was it. Wife 440 road runner no issues at all.  :2cents:
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #7 on: August 31, 2010 - 07:08:22 PM »
That was pretty much my case with the 78036's. Just a little work to get around the mini starter, and a couple of bangs to get around the power steering box. No biggie.    :2cents:
I just want to say ceramic coated headers are the way to go. Still some heat when you are driving at crazy speeds, but MUCH better than uncoated headers. No hot foot issues anymore for me.    :bananasmi
Offline tommyg29
« Reply #8 on: August 31, 2010 - 08:18:41 PM »
my shortys didnt fit either. Had to crimp tubes to half size on each side to make them fit, and I'm so unhappy with them I think I want to put the hp's on instead. Just isnt enough room on the sides unless they are very specially designed, and seems like then its just the luck of the draw, cause I know for a fact my engine placement is spot on factory specs (the measurements from center crank, etc)
« Reply #9 on: August 31, 2010 - 08:36:33 PM »
All the members that have had no issues with fitment, are you running power steering or manual steering? With manual steering box I could see it fitting ok but not with a power box? :clueless:
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #10 on: August 31, 2010 - 08:44:11 PM »
Brad,  yep all 3 have OE power steering and suspension. all use the same 78036 header, ceramic is nice.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline Road_Runner
« Reply #11 on: September 04, 2010 - 11:18:21 PM »
I also had a major fit issue with my 383 Roadrunner's mini starter.  I could have dented them to fit, but I paid extra for the coating and there was no way I was banging on coated headers making them almost certain to rust there.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
