Author Topic: need stripped full frontal images.  (Read 2953 times)
Offline Beck
    • BECK KUSTOMS
« on: August 31, 2010 - 07:52:08 PM »
as in images of the front of an ebody with the fenders, hood, grill, bumper etc removed.
although images of naked ladies never hurt...
i have stripped the front of my cuda and it's looking pretty damn crooked...
cheers,
aaron
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: need stripped full frontal images.
« Reply #1 on: August 31, 2010 - 09:12:44 PM »
do you have the cross dimension from the cowl top to aprons? if not i can send them to you
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline Beck
    • BECK KUSTOMS
« Reply #2 on: August 31, 2010 - 09:31:24 PM »
any dimensions would be very much appreciated!
i have the factory shop manual, and it has the frame dimensions, but i haven't had a chance to measure my car up yet.
i have some cracks and rust to repair before the car goes off to the chassis straightener...
Offline challenger_73
« Reply #3 on: August 31, 2010 - 11:22:46 PM »
This is all that I have at the moment
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: September 01, 2010 - 01:35:30 AM »
here are a couple....
« Last Edit: September 01, 2010 - 01:40:24 AM by ntstlgl1970 »
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: September 01, 2010 - 12:24:10 PM »
I have that in a PDF, I'll email that to you. Be carefull, need to put a k-frame in. the front end is flexing and stressed with out it. Other wise you'll never be able to have proper panel alignment with it on the spinner, and it will change and move when you take the pressure off and relax the body.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline FRSHFSH
« Reply #6 on: September 01, 2010 - 01:09:38 PM »
hopefully this helps.  it was this morning, on the way for paint!!  :ylsuper:
"We will remodel the house once the cuda is finished"
Offline TreeFrog
    • TreeFrog
« Reply #7 on: September 01, 2010 - 04:20:24 PM »
MAN!
I thought this one was supposed to go to the Babes section //////
 :bigsmile:
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline Beck
    • BECK KUSTOMS
« Reply #8 on: September 01, 2010 - 05:15:14 PM »
cheers guys! these are just what i need, especially the ones from dead front on.
keep em coming!
from what i can see those radiator support frames are meant to be straight up and down. ha ha
mine aren't.
not by a long shot...
Alaskan_TA
« Reply #9 on: September 02, 2010 - 08:17:25 PM »
Do yourself a favor & put it on the frame rack first.  :2cents:
Offline Beck
    • BECK KUSTOMS
« Reply #10 on: September 02, 2010 - 11:21:42 PM »
hey alaskan, you think so?
the drivers side chassis rail is cracked right through...  i figured it would be pointless trying to straighten the front end when such a major section is flapping around.
would it not stop everything from being aligned correctly if it could just bend at the broken rail?
i was planning on at least welding up or doing a degree of plating over the rail, then straightening the front end.
than plating the rail completely, and adding a bunch of extra bracing to the rails, k member, and inner fenders.
what do you think?
cheers,
aaron
