Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Dana 60 oil Capacity
« previous
next »
Print
Pages: [
1
Author
Topic: Dana 60 oil Capacity (Read 3842 times)
73EStroker
Sr. Member
on:
August 31, 2010 - 08:54:15 PM »
So I have a Dana 60 with the green bearings/axles from Moser axle. They say the double sealed bearings require no inner seals such as stock applications. I have a tiny leak at the right side so the question is "am I overfilled with oil?" If anyone knows the oil capacity for this diff please advise as I filled it to the drain plug. Otherwise I will dismantle and add the seals.
Logged
Barry (Salmon Arm)
Chryco Psycho
Administrator
C-C.com Guru
Re: Dana 60 oil Capacity
Reply #1 on:
September 01, 2010 - 01:36:26 AM »
approx 3 lt
you are supposed to fill to the drainplug
Logged
Aussie Challenger
Resident
In Kansas loaded for Drive to West Coast.
Reply #2 on:
September 01, 2010 - 10:16:09 AM »
Did the bearings have a sealing "O" ring on the outside and I have never trusted the internal seals on those bearings. Another thought is the bearing on the correct way as some have directional seals.
Logged
73EStroker
Sr. Member
Reply #3 on:
September 01, 2010 - 08:39:29 PM »
Dave - I am not 100% sure about the sealing ring but me thinks to pull the axles and put the stock seals in. If oil has migrated through the bearings then they will be washed clean of grease so will require new bearings as well. Wish I had done the setup that CP did - Dana conversion with the double taper roller bearing from a Ford 1/2ton truck. That requires special ends to be welded on to the housing. CP is that guy still doing the ends in Calgary? just in case I change my mind.
Logged
Barry (Salmon Arm)
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
September 02, 2010 - 11:33:45 AM »
Yeah he is still doing housings in his spare time , he works for the city full time now
I thought the Green brgs were supposed to run wet with diff oil , I think they would fail quickly with inner seals in place
Logged
73EStroker
Sr. Member
Reply #5 on:
September 02, 2010 - 10:21:44 PM »
I'm not 100% sure but I could have sworn that I had seals on both sides. Will look when I pull the axles.
Logged
Barry (Salmon Arm)
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
