Author Topic: Rear disc brake conversion kits for 74 Challenger?  (Read 8423 times)
Offline FBJJChallenger
« on: September 01, 2010 - 09:27:12 PM »
Hey Guys,
I want to convert from drum to disc in the back and was wondering what your opinion is as far as the best (in the range of $500-$800) conversion kit to buy? SSBC makes one but it only says it works on 70-72?? Any help/advice is much appreciated!
James
Re: Rear disc brake conversion kits for 74 Challenger?
« Reply #1 on: September 01, 2010 - 10:32:10 PM »
I think someone on here is selling a kit for like $300
« Reply #2 on: September 01, 2010 - 10:37:23 PM »
 :iagree:  Ya I tried to find it for him , but can't find it? Sold maybe? :dunno:
« Reply #3 on: September 01, 2010 - 11:30:03 PM »
I've tried google searching for them without much luck either. Hmm....
James
« Reply #4 on: September 02, 2010 - 08:43:26 AM »
Okay, my mistake, $500 which includes shipping, and it is a SSBC kit.
http://www.cuda-challenger.com/cc/index.php?topic=68862.0
« Reply #5 on: September 02, 2010 - 11:29:33 AM »
The SSBC kit has very wide calipers & they interfer with the sway bar , ask me how I know  :banghead:
 Dr. Diff supposedly has a good conversion kit but I have no experience with ti
« Reply #6 on: September 02, 2010 - 04:54:18 PM »
Yea,
And the SSBC's say they fit 1970-1972 Challengers, so I'm wondering if there would be issues there as well.....
« Reply #7 on: September 03, 2010 - 02:26:01 AM »
if you have the rear sway bar it will interfere on any Ebody
Offline torqueaddict
« Reply #8 on: September 04, 2010 - 11:05:59 AM »
Will rear disc brakes really give you significantly more stopping power? If so Iwould be game to get a set.
1972 Challenger  (O O [======R/T=] O O) 1970 clone
« Reply #9 on: September 04, 2010 - 12:02:15 PM »
Not really , the drums are limited so they do not use max power , the difference comes in with multiple hard stops & the brakes tend to overheat
Offline Katfish
  • 70 Challenger
« Reply #10 on: September 04, 2010 - 03:27:46 PM »
I really question the need for rear discs, other than the cosmetic appeal.  I have the 11.75 discs in front with 11x2.5 drums in the rear.  I even put the smaller 7/8" wheel cylinders to help limit the rear's.  They still lock up before the fronts.  So the the standard solution is to put in an adjustable valve.  But what does this do?  It effectively limits the pressure to the rear.
So what do you think is going to happen with discs on the rear?  You'll have to crank the adjustable valve down to nothing.
I hear the arguments about unsprung weight, so if it's worth $600-800 to you go ahead, I don't get it.
Now if you are putting 13" or larger discs up front, it might help, but I still wonder.
« Reply #11 on: September 04, 2010 - 03:32:43 PM »
So even aftermarket disc in the front is still not a huge gain is what your saying
Offline Katfish
  • 70 Challenger
« Reply #12 on: September 04, 2010 - 03:37:25 PM »
No, don't get me wrong.
I went from 4-wheel drum (11") to 11.75" disc up front.  Huge improvement.
I just question whether there's a need for the rear.
Lot of good info here:
http://www.moparaction.com/tech/archive/disc-main.html
Offline ajantics
    • Yeah......Im a drummer!
« Reply #13 on: September 04, 2010 - 03:46:39 PM »
Would that still apply if you used the hotchkis rear sway bar instead of the factory aar style sway bar?
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
« Reply #14 on: September 04, 2010 - 07:28:15 PM »
not sure how the Hotchkiss bar fits but if it is above the diff & links down onto the rear leaf springs it will probably hit the bar
