Rear disc brake conversion kits for 74 Challenger?
Author Topic: Rear disc brake conversion kits for 74 Challenger?  (Read 8427 times)
Re: Rear disc brake conversion kits for 74 Challenger?
« Reply #15 on: September 04, 2010 - 07:40:57 PM »
not sure how the Hotchkiss bar fits but if it is above the diff & links down onto the rear leaf springs it will probably hit the bar
It mounts below the rear end and links up to the frame.
Offline miketyler
    • www.miketyler.net
« Reply #16 on: September 04, 2010 - 08:14:19 PM »
Diff's kit works great. I have some pics around here somewhere
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline FBJJChallenger
« Reply #17 on: September 04, 2010 - 11:42:10 PM »
Yea,
I'm questioning if I need them after more asking around. I talked to the person who's doing my resto and he said that having the discs on the front you really don't need them on the back. He also said that the front do 60-65% of the braking and the back take up the rest. So unless you are planning on a bunch of hard stops it's not really necessary.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #18 on: September 05, 2010 - 04:21:24 AM »
I really question the need for rear discs, other than the cosmetic appeal.  I have the 11.75 discs in front with 11x2.5 drums in the rear.  I even put the smaller 7/8" wheel cylinders to help limit the rear's.  They still lock up before the fronts.  So the the standard solution is to put in an adjustable valve.  But what does this do?  It effectively limits the pressure to the ahead, I don't get it.
Sounds like something is worg with your brake bias did you change your brake  balance vaulve when you added the new front disks?
The front should always lock first.
Go Fast & Have Fun...
Offline miketyler
    • www.miketyler.net
« Reply #19 on: September 05, 2010 - 08:31:25 AM »
Drums can look really funky behind custom wheels. For me it was more of a "look" thing
72' Cuda restomod
70 Mustang Mach 1
« Reply #20 on: September 05, 2010 - 11:46:23 AM »
rear drums generally will lock up first without a variable proportioning valve   , there is less load on them
Offline Katfish
  • 70 Challenger
« Reply #21 on: September 05, 2010 - 12:25:10 PM »
Do you have a side shot with the rim on?  What size disc do you have on the rear?
Offline Katfish
  • 70 Challenger
« Reply #22 on: September 05, 2010 - 12:28:40 PM »
My point exactly!  Why would you put discs on the rear (other than for cosmetics) and then turn down the line pressure so much to limit the "improved" braking?  The system needs to be balanced, and the truth is the fronts do almost 75% of the braking.
Don't get me wrong, if I had unlimited funds I'd throw a set of the 13 or 14" discs on front and then get some discs for the rear too.
Offline miketyler
    • www.miketyler.net
« Reply #23 on: September 05, 2010 - 03:16:21 PM »
a rusty drum (or even a painted one) just doesnt look right  :smokin:
72' Cuda restomod
70 Mustang Mach 1
Offline Katfish
  • 70 Challenger
« Reply #24 on: September 05, 2010 - 05:09:23 PM »
10.87" Discs do look nice, but the large finned drums actuallly fill out the rims more.
Outside Diameter 13.62" / 5 Bolts / Finned
I'd like to get 13" or larger if I was going to put them on my 18" rims.  But that would really be defeating the purpose.
Offline miketyler
    • www.miketyler.net
« Reply #25 on: September 05, 2010 - 06:14:34 PM »
I doubt you are going to find too many that actually prefer the look of drums but to each his own. Maybe on an all drum car?  I think discs look better, match the front, easier to change shoes, etc.
But no doubt about it, converting to them is anything but cheap.
72' Cuda restomod
70 Mustang Mach 1
Offline ajantics
    • Yeah......Im a drummer!
« Reply #26 on: September 05, 2010 - 06:50:25 PM »
Hi , are you running the ssbc rear brake kit and if so what sway bar are you using?  :2thumbs:
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Offline miketyler
    • www.miketyler.net
« Reply #27 on: September 05, 2010 - 07:51:36 PM »
Am running Dr Diff's kit, wheels are 17x11. Also has OEM rear sway bar, did have to relocate the holes in the attach brackets slightly.
72' Cuda restomod
70 Mustang Mach 1
Offline ajantics
« Reply #28 on: September 05, 2010 - 07:57:13 PM »
Thank you for the info! :2thumbs: I have a dr diff kit on the way with a 1" offset spring hanger kit so i was trying to figure out want to do. :pullinghair:
70 Barracuda
73 'Cuda
2009 G37s
