Author Topic: Water pump installation  (Read 577 times)
Offline lime73
« on: September 02, 2010 - 05:13:39 PM »
Installing a new aluminum water pump from mancinis and there is no weep hole.  There is however a yellow dot around the area of the where the weep hole would be. should i mount with that down down or does it not matter?
Re: Water pump installation
« Reply #1 on: September 03, 2010 - 02:34:03 AM »
weird , usually there is a hole if only to allow for heat expansion
I would call Mancinis & see if there pumps normally have the hole & this one was missed accidentily
usually there is Top marked on the pump housing too
