Author Topic: 11.75 Disc Brake Upgrade problem!  (Read 5173 times)
Offline sac2dude
« on: September 06, 2010 - 01:37:01 AM »
I'm attempting this upgrade on my '70 Challenger conv.   I pulled the spindles off of a '75 Dart, checked the measurements, and indeed the lineup with those given in the mopar action article http://www.moparaction.com/tech/archive/disc-main.html.
I pulled the caliper adapters off of a '79 Newport.  No issues, they bolt on well and measure fine.
Went to Kragen, bought a pair of 11.75 rotors (specifying the same '79 Newport) and a set of inner/outer bearings for the '75 Dart, along with inner hub seals.
Result: Bearings fit on spindles fine.  Outer bearing fits in the 11.75 rotor, but the inner bearing and hub seal are too small, and fall into the rotor.
I don't get what the problem could be!
Any ideas?
Thanks!
Offline 72bluNblu
Re: 11.75 Disc Brake Upgrade problem!
« Reply #1 on: September 06, 2010 - 02:28:10 AM »
This is your problem right here. You need inner bearings and seals for that '79 Newport (or any other car with the 11.75 rotors stock). The spindle diameter is the same for '75 or '79. In fact, its the same from at least '73 to '81 (its probably a much longer run than that). So the internal bearing diameter is the same for the '75 parts and the '79. But as you've discovered, the external bearing diameter is different on the inner bearing, this is because the 11.75" rotors have a larger internal diameter on the inside part of the hub.
I would also check to make sure the outer bearings have the same dimensions as those for the '79, just to make sure there isn't a thickness variation. Wouldn't be any fun to find out that you can't line the hole in the spindle up with the castle nut because the outer bearing is too wide/narrow.
I have a set of 11.75 rotors on my car, the install thread is here http://www.cuda-challenger.com/cc/index.php?topic=56565.0. Although I didn't list anything about which bearings I used. On page 3 there's a list of all the 11.75" rotor cars, any of them should work when giving a reference for the bearings.
« Last Edit: September 06, 2010 - 02:35:15 AM by 72bluNblu »
Offline aris_unlimited
  • Project in full swing
« Reply #2 on: September 06, 2010 - 05:18:00 AM »
I've been interested in doing a rear disc brake conversion on my 'cuda. Just curious will the 11.75" rotors still allow the use of stock size wheels (15's)?
Cuda is gone :(
74 satellite, daily driver/project now
Offline Katfish
  • 70 Challenger
« Reply #3 on: September 06, 2010 - 08:18:36 AM »
Here's the parts list I used for the conversion
raybestos w/pad RC4103/4 $36.00
78 charger (slider)
outer bearing BR2 $6.00
78 charger
wearever rotor YH141132 $52.00
78 charger
dorfman banjo bolt 13938 $5.00
inner wheel bearing BR17 $8.00
77 charger
inner seal 19500 $2.00
77 charger
raybestos hose 4536755 $15.00
76 duster
« Reply #4 on: September 06, 2010 - 11:16:00 AM »
15" yes. 14", no.
Offline mopar12372
    • mopartech
« Reply #5 on: September 06, 2010 - 12:40:48 PM »
more information please  :cheers: thankyou!
RESTO PICTURES
Offline sac2dude
« Reply #6 on: September 06, 2010 - 04:09:11 PM »
Thanks for the replies!
So, the bottom line is that if my spindle measures the 1 3/8" diameter, then the '79 Newport bearings oughto work just fine.
But I tried 'em.  Yes, they fit the races on the rotors... but they're LOOSE on the spindle!   AAARRGGGHHH!!!
I've measured the spindle repeatedly... same number:  1 3/8
I'm gong to have to make another trip to Kragen to return these.  Perhaps there were differences that year?  I have no idea what to ask for.   ???
Offline cudazappa
« Reply #7 on: September 06, 2010 - 05:12:01 PM »
You may have the wrong bearings.  P/N might be correct, but wrong bearing inside.  BTDT.  Or made wrong. BTDT, too.
73-89 A/B/E/F/J/M/R (*whew*) disc spindles all use the same inner and outer bearings.  I've done the big rotor swap myself on a couple of rides, I've re-used bearings from the 10.87" setup to the 11.75".
Kragen's part number for the inner bearing is SA17 or A17 (two choices, prices), and outer wheel bearing SA2 or A2 (same deal, two different MFRs)
2015 Dart GT - Daily Driver
Offline sac2dude
« Reply #8 on: September 06, 2010 - 06:37:06 PM »
Okay, just returned from Kragen.  Apparently I DO have the right bearings:  BR17 and BR2
But the parts guy thinks they got me the wrong rotors.  The part# looked incorrect to him (7034), so they have some 7038's coming in.  I have no idea what the difference is, but so long as everything ultimately fits... I'm happy.
Offline cudazappa
« Reply #9 on: September 06, 2010 - 09:43:58 PM »
off of Kragens website, the disc should be Wagner #BD60474
The numbers they are giving you are the Raybestos #s.  7034 is for a C-body newport.  (pre-79, might've gotten the wrong year).  :faint:  7038 is the 11.75" B/R rotor!  :woohoo:
Offline ChallengerHK
« Reply #10 on: September 06, 2010 - 09:59:17 PM »
I had this happen the last time I replaced front bearings: right part number, wrong part.
- Han Solo, Star Wars
