Just e-mailed a supplier , same one that suppies the e-bay link. Here is the responce!
Lawrence M Bush
NorthWestMustang LLC
ClassicLEDs LLC
WWW.NorthWestMustang.COM
3128 Marvin Dr.
Eugene, OR 97404
541.463.7623 OP
541.505.7513 Fax
541.554.4751 Cell
email:
NorthwestMustang@comcast.netSeptember 9, 2010
Thank you for asking about our 1970 Challenger LEDs.
This new board contains 208 super bright 5mm red LEDs on EACH board for a total of 416
LEDs per system.
Each board is design to fill the entire lens. The LED board sits on a black plastic ABS panel
and is shaped to fit within the area of the lens. You may remove the rear housing if you wish, giving a
new smooth look within the trunk area.
The non sequential system plugs into the OEM wire harness using our exclusive 1156 bulb based wire
harness
The sequential system contains a wire harness with a computer board control unit within the harness.
This system connects to the OEM harness with wire taps (included) for a simple installation. In
addition, due to the large number of LEDs, the system must be attached to a constant 12volt power
supply. The harness contains enough wire to plug into the OEM fuse box under the dash. Should you
have a battery in the trunk, you may attach to the battery.
Should you wish to stop the sequence operation, a small button on the control unit allows you to
stop and restart the sequence operation at any time.
Pricing:
Non Sequential systems $189.95
Sequential system $239.95
Does not include shipping
ClassicLEDs is a small family owned business here in Eugene, Oregon.
ALL our products are manufactured here in Oregon. Our bulb based wire harness is imported to us under contract.
ALL ClassicLEDs products are shipped to Canada or Mexico duty free under NAFTA.
Again, thank you for asking. I look forward to providing you with a truly unique product.
Lawrence M Bush, Owner
NorthWestMustang, LLC
ClassicLEDs LLC
3128 Marvin Dr.
Eugene, OR 97404
541.463.7623
Each board contains 208 5mm
Super Bright red LEDs
