Author Topic: Has anyone seen these LED tailights in person? 1970 Challenger  (Read 50123 times)
Re: Has anyone seen these LED tailights in person? 1970 Challenger
« Reply #165 on: May 08, 2012 - 08:44:15 PM »
I most likely cooked because it got too much voltage/current.  You could put one in that takes more of that but...that's kinda like fixing a 20A fuse that keeps popping by putting in a 30A fuse.  It might stop that from frying but something else (wiring, led, resistor, etc) down the road is going to get more than it expected and probably end up cooking instead.
Looking at some specs for a IN4001 diode .... 50V, 1amp, 175C?
Offline Jamiez
  • Retro
« Reply #166 on: May 08, 2012 - 08:58:56 PM »
Yes looking at the data sheets, those appear to be the maximums.  It's been 15 years since I did any real circuitry work however.
« Reply #167 on: May 08, 2012 - 10:07:47 PM »
Be nice to find 50v 2amps maybe?
Offline ShelbyDogg
« Reply #168 on: May 08, 2012 - 10:48:04 PM »
Brad, all of my parking and running lights in my 70 challenger only draw 3.3 amps.  Go to Radio Shack and get a pack of those diodes and quit wasting time. 1 amp is enough for a bunch of LEDs. You probably shorted the board  somewhere to ground. You don't put a bigger fuse in a circuit because it blows.
« Reply #169 on: May 08, 2012 - 10:51:53 PM »
lol ok I will. maybe tomorrow if I have time
« Reply #170 on: May 09, 2012 - 12:35:48 PM »
Ok just found this really cool electronics supply/hobby place they set me up with new diodes. Bad news is you have to buy a pack of 10...... they were a buck for all ten.  :roflsmiley:
Also bought a really good quality   soldering iron..... that was 60 bucks!  :grinno:  Oh well once you have the tools your set for life!
I might give this a go later tonight if I have time.
« Reply #171 on: May 09, 2012 - 05:21:36 PM »
 :woohoo: all fixed! cost ten cents plus the cost of the soldering iron. Cheapest car repair I've ever had! :grinyes:
The guy at the electronics supply said it's like fuses....if one goes no problem but if two go then you have a problem. It could have just been a faulty diode he said? I guess time will tell.....
Offline ChallengerHK
« Reply #172 on: May 09, 2012 - 05:31:41 PM »
Good luck with it.
- Han Solo, Star Wars
Offline Jamiez
  • Retro
« Reply #173 on: May 09, 2012 - 05:47:09 PM »
Of course not....you put some thick wire in there so it never pops!
 :roflsmiley:
Glad it worked for you Brad :)
« Reply #174 on: May 09, 2012 - 05:50:32 PM »
Brad,
 I'm glad it worked out for you.   :cooldancing:
You'll have 9 more diodes to lend me if mine fails, right??   :lol:
« Reply #175 on: May 09, 2012 - 06:06:02 PM »
Brad,
Sure thing!  :2thumbs:  except the postage would cost more than the parts!  :roflsmiley:
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« Reply #176 on: May 10, 2012 - 04:35:11 AM »
Nicely done Brad.
Offline ShelbyDogg
« Reply #177 on: May 10, 2012 - 11:09:14 AM »
I use a small 15w soldering iron for the small stuff a nd a big adjustable soldering station for the big stuff. Eomponents don't like too much heat or they fry. Only use enough heat to melt the solder then get off of it. Use a heat sink clip on the legs if you have to heat the part up a long time.
« Reply #178 on: May 10, 2012 - 05:41:03 PM »
I bought a Weller, and a fine point tip.
WLC100
http://www.cooperhandtools.com/brands/cf_files/model_detail.cfm?upc=037103059963
Thanks for all your help and encouragement Shelbydogg and Jamiez!  This was my first leap into electronics repair and it went pretty well! :2thumbs:
Offline ShelbyDogg
« Reply #179 on: May 11, 2012 - 02:03:36 AM »
WLC100
That adjustable soldering station will work well for anything that you will work on.  I've been playing with electronics most of my life. Just remember E=IR   :bigsmile:
