Author Topic: Has anyone seen these LED tailights in person? 1970 Challenger  (Read 50119 times)
Offline ChallengerHK
Re: Has anyone seen these LED tailights in person? 1970 Challenger
« Reply #30 on: September 22, 2010 - 08:17:39 PM »
Mike, you want any help? As I've said to several others, I make great unskilled labor.
- Han Solo, Star Wars
« Reply #31 on: September 23, 2010 - 04:52:07 AM »
Mike did you get the sequential upgrade on them there tail lights?
Yes. It will be interesting to see what it looks like.
Offline purple1
« Reply #32 on: September 23, 2010 - 07:48:01 AM »
:popcorn:
Dave
Offline bigblue73
« Reply #33 on: September 23, 2010 - 10:11:28 AM »
If you have not converted to LED's in the front you should not need the "No Load" flasher.  Yet?  Remember that the socket's provide the ground if you are plugging into the socket for power.  If you have the socket outside of the base you may see feedback through your marker lights.  The marker lights will blink is what I'm trying to say.  I'm running his units in my '73.
« Reply #34 on: September 24, 2010 - 05:49:57 PM »
UPDATE:
  I'm most of the way there. It's 95*F right now, so I have lost my enthusiasm.   :eek4:
I think the car is driveable as is, but I gotta problem(big surprise)  :lol:  The brake lights are fine, as well as the parking lights. The left turn signal is fine also. It's when I turn on the right turn signal that things go down the pooper. The right tail light flashes as it should, but there is a ghost like flash on the left tail light as well. It is much dimmer, but noticeable. Also when the right turn signal is on, both the front and back side markers lights flash.   :screwy:  I'm guessing a ground problem, but where? I installed the old 1157 bulbs in their sockets that are just sitting on the bottom of my trunk now. They didn't flash, but they made the ghost flash on the left brighter, so I knew that wasn't the answer. I also installed a couple of the empty sockets back into the tail light housings, but that made no change. I just hope this isn't something on the control board that needs attention because it is sealed in shrink wrap to protect it. I'll also add there is a button on the control board to make these LED lights act without the sequential thing going on. As I suspected, that made no difference.
Since I'm the guinea pig here, I don't expect anyone has gone thru this before, but I'm just telling you where I'm at now. The good news is the original turn signal flasher seems to work fine. Maybe I'll get back at this in a few days...   :working:
In the mean time, I made my first You-Tube clip. It's short, but you can see what's going on.
« Reply #35 on: September 24, 2010 - 06:20:59 PM »
I have no answer for you, but they do look good.
« Reply #36 on: September 24, 2010 - 06:22:42 PM »
Hummm? bummer? did you contact the supplier? Maybe it's defective in the "computer" part? Send them the video? Looks good though! I bet it will really light up well at night! :thumbsup:
« Reply #37 on: September 24, 2010 - 06:28:05 PM »
What happens when the 4 way flashers are on? I wonder if it's the flasher unit?  Is your flasher the electronic type?
« Reply #38 on: September 24, 2010 - 07:31:28 PM »
No, my flasher is the original. I haven't put on the emergency flashers yet, so I don't know what would happen there.  At the risk of sounding stupid(er), where is the emergency flasher located? Maybe I should start there?    :thinkerg:  I just want to get this figured out for the rest of you. I do like it, and it is much brighter than the old 1157 bulbs. Given my old system worked fine, I have to think the problem is the new control board, but I hope not. Stay tuned...
« Reply #39 on: September 24, 2010 - 07:59:41 PM »
Just turn on the signal light and listen for the clicks. Mine was clipped to the dash frame behind the ash tray. I'm betting if you try a electronic flasher unit it will work? I have a few in my toolbox but they are cheap at any parts store.
« Reply #40 on: September 24, 2010 - 08:04:28 PM »
OK guys,
  It's worth a shot.     :wave:
« Reply #41 on: September 25, 2010 - 06:20:19 AM »
flasher is behind the cig lighter under the dash
Turn signal flasher
Emergency flasher is clipped to the dash frame by the steering column.
« Reply #42 on: September 26, 2010 - 04:52:35 AM »
Another update:
  I've been in contact with Larry, the apparent do-it-all there. He had me do a few things, and he thinks the problem is a short somewhere on the control board. He said he would make me another one and send it out, hopefully tomorrow. I have to say he seems like a real stand up guy. I hope the second control board gives me a little better results.   :swaying:
« Reply #43 on: September 26, 2010 - 07:43:27 AM »
 :popcorn:   nice to see they stand behind their products! :2thumbs:
« Reply #44 on: September 26, 2010 - 10:22:35 AM »
That looks cool MEK.
'69, & '70 Mercury Cougars had sequential lights like that. They used a 12v motor rotating a step switch. Maintenance intensive.
