Author Topic: 1970 - 71 does anyone have pictures of tail panel fit  (Read 8931 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: 1970 - 71 does anyone have pictures of tail panel fit
« Reply #15 on: September 25, 2010 - 12:30:30 PM »
When mounting the 2 piece trunkfloor with quarters and tailpanel still on,
how do you get the lip from the trunkfloor under the tailpanel? :clueless:
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline swede-cuda
« Reply #16 on: September 25, 2010 - 03:11:16 PM »
 :clueless:i dont think the lip exists on 2-piece trunk floors :dunno:its sort of a easy repair :picture:the lip on the 2-piece trunk floors ends on the inside of the trunk,as in dont cut your original before youve meassured it up. :cooldancing:so when you use the 2-piece floor you have to keep the part of the floor thats in between the taillight panel and the beam thats under it.this piece of the trunk floor that you leave still attatched to the car,then folds up 90degrees up over the bottom of the tail panel.at least thats what i red on this forum if i remember it right :hyper:good luck
Offline mopar12372
    • mopartech
« Reply #17 on: September 26, 2010 - 10:54:48 PM »
true/ or you have to make the 1 1/2 peace for the rear .
RESTO PICTURES
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #18 on: September 27, 2010 - 07:17:21 PM »
what trunk floor did you buy put in. All of the ones I have seen have the 90 degree lip like the one piece pans???????
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline mopar12372
    • mopartech
« Reply #19 on: September 28, 2010 - 02:49:43 AM »
2 peace. it said in the instructions that the rear of the floor needs to be kept but i cut it out because of rust and previouse repair attempts.
RESTO PICTURES
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #20 on: September 28, 2010 - 08:34:36 AM »
so you created your own problem by removing the lip edge with nothing to replace it with,  :dunno:
if this picture is correct you short by a lot, looks like it ends on top od the crossmember which is way away from the tail panel
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #21 on: September 28, 2010 - 08:36:06 AM »
you will have to fabricate the remaining floor edge to properly fit the tail panel.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline mopar12372
    • mopartech
« Reply #22 on: September 28, 2010 - 02:15:01 PM »
yes the last 2 inches are flat not a problem here . what is that picture for? im not having fitment issues i just dont know if the panel gets installed flush with the qpanel seam or set in a little . the pictures ive been looking at have been a little of both so ill probably play with it and figure out what looks best. i removed the 73 panel because there was soo much bondo in it that the 1970 would feel right at home in its place .  soo the picutres can be seen i thought they didnt upload . intresting
RESTO PICTURES
Offline usraptr
« Reply #23 on: September 28, 2010 - 09:58:06 PM »
I also recently installed a two piece trunk pan and tail light panel.  Hope these pics help.   :2thumbs:
(Edited 8-1-17)
Offline mopar12372
    • mopartech
« Reply #24 on: September 29, 2010 - 11:10:19 PM »
 :2thumbs: perfect yeeeehhaaaaa !!!!!  :bigsmile:
thankyou just what i was looking for with out the guess work . ok i thought i was going crazy .
thanks guys for all of your help . i knbow have a direction :working:
RESTO PICTURES
