Many people use WD-40 for vacuum leak diagnosis. It temporarily seals a leak, raising (or lowering) the rpm. I prefer using starting fluid, as it ALWAYS raises the rpm, and only raises it where it is sucked into the leak. If you use ether, use care, as it is explosively combustible. Use it sparingly, and be careful not to generate a "false positive" by accidentally feeding it into the carb throat.
