Author Topic: small constant backfiring out of exhaust  (Read 5166 times)
Offline Traction Dynamics
Re: small constant backfiring out of exhaust
« Reply #15 on: September 11, 2010 - 11:53:34 PM »
I had this problem with a 318 in my challenger. after trying most all of these suggestions it turned out to be a bad lobe on the cam :swear: Hope this isn't the case, but it is something else to check.
Offline barryv
« Reply #16 on: September 12, 2010 - 03:44:20 PM »
when i spayed the carb cleaner around edges of intake manifold and saw it bubbling on the driver side more than the passenger side.does this mean i have a vacum leak,thanks
Offline mopar12372
    • mopartech
« Reply #17 on: September 12, 2010 - 04:46:20 PM »
possible vaccuum leak-flammible carb spray will raise engine speed nonflammible will lower or do as you stated . another good test is to limit the ari into the carb ,see if the rpm raises or lowers . if rpm raises you have a major vaccuum leak . popping exhaust minor fix is usually exhaust leak , burnt or corroded plug wires , idle mixture lean , fauled plug or burnt , carbonized cap or rotor , basic tune up stuff . put a vaccuum gauge on it , ported vaccuum if it hasnt any reading and you cant make any adjustment a vaccuum leak you may have . if this dosnt correct anything them you need to test further in other areas. start with basics , make one correction at a time and move forward until repair is made .
RESTO PICTURES
Offline barryv
« Reply #18 on: September 12, 2010 - 05:26:04 PM »
thanks for the tips
Offline barryv
« Reply #19 on: September 17, 2010 - 02:50:58 PM »
ran engine today and covered top of carb with my hand when engine was running. engine continued to run and idle seemed higher. is this a vacum leak problem,thanks
« Reply #20 on: September 17, 2010 - 03:33:31 PM »
Sounds like a vacuum leak. Do you have power brakes by chance?
Offline barryv
« Reply #21 on: September 17, 2010 - 05:27:10 PM »
yes. pugged up the vacum line going to booster.still same problem,could it be from intake .i loosened 3 bolts to adjust throttle bracket can this be the cause of it. thanks
Offline barryv
« Reply #22 on: October 24, 2010 - 07:50:40 PM »
finally found my problem. evidently one or more plug wires were causing miss. replaced wires yesterday just to eliminate wires as cause and sure enough no more miss with new wires
