Author Topic: Questions about my 70 Cuda...  (Read 19927 times)
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: Questions about my 70 Cuda...
« Reply #60 on: May 13, 2011 - 09:49:10 AM »
That is a standard part. Some call it an Oil Pressure sending unit. The rockauto web site has it and calls it an Oil Pressure Switch (with gauge).
Standard Motor Products part #PS59
« Last Edit: May 13, 2011 - 09:53:08 AM by purple1 »
Worlds first e-body trailer.    Severna Park, Maryland
« Reply #61 on: May 13, 2011 - 09:53:23 AM »
Here it is. I'm surprised it's so cheap.
    http://www.summitracing.com/parts/SMP-PS59/
Offline purple1
« Reply #62 on: May 13, 2011 - 10:24:18 AM »
Mike, way better price at rockauto... $12.36
Offline LukeSkywalker
  • Plymouth
« Reply #63 on: May 14, 2011 - 11:28:00 AM »
Ordered ! Thanks guys !
Offline FC7 CUDA
« Reply #64 on: May 15, 2011 - 07:25:29 AM »
wards radio can rebuild the radio.. he did mine it came out great!! stock radio can be  worth some money
  • Plymouth
« Reply #65 on: May 26, 2011 - 03:10:20 AM »
Can anyone tell from pics here what color my car is? It's not tor-red, chrysler engine orange and its not hemi orange as far as we could find from the local paintshops database. The paintshop shot it with a scanner but came up with a bad match..
Offline dutch
« Reply #66 on: May 26, 2011 - 04:39:00 AM »
looks like vitamin-C to me   :dunno:
*** Bart ***
Offline GranCuda1970
« Reply #67 on: May 26, 2011 - 09:49:40 AM »
  • Plymouth
« Reply #68 on: June 18, 2011 - 04:30:46 PM »
Houston - we have a problem..
I had a leaky Master Cylinder without brake-booster, which sucked..
I ended up buying the Wilwood Front Disc brake kit and a Cardone Power Brake Booster 54-73701 plus a new Master cylinder because the old was abit leaky..
Anyway - the CARDONE Brake booster is a problem because the rod that connects to the pedal is like 5 cm too short..?
Anyone had this problem or know the solution to this?
Sorry bout this.. there's prob gonna be a sh*tload of n00b questions coming from me now, till August 15th ..
« Last Edit: June 18, 2011 - 04:33:50 PM by LukeSkywalker »
« Reply #69 on: June 19, 2011 - 08:59:14 AM »
I assume you have the extended linkage from your old booster ? It is a cantelever system for lack of better terminology
  • Plymouth
« Reply #70 on: June 19, 2011 - 01:02:08 PM »
No. I didnt have a Booster before... Only Master Cylinder, and the pushrod for that goes from the BOLT on the pedal and directly into the Master cylinder..
The old master cylinder rod is about 6" long, and the rod coming out of the booster is about 4"...
Do you know where I can get this cantelever linkage? Does it build about 2" ?
EDIT: - Is this what I need? http://cgi.ebay.com/ebaymotors/DISC-BRAKE-PEDAL-LINKAGE-71-CUDA-CHALLENGER-CHARGER-GTX-/120728381202
EDIT AGAIN: - Nevermind, I found it here : http://www.brewersperformance.com/products.asp?cat=279
« Last Edit: June 20, 2011 - 05:05:32 PM by LukeSkywalker »
  • Plymouth
« Reply #71 on: June 26, 2011 - 06:43:20 AM »
Fuel pump installation failure...
I removed the original fuel pump, opened it and the membrane was shot.. Bought a new one. Tried to install it, and it broke off on one side where the screw goes. Noticed there is a screw a couple of millimeter below where the pump goes, and a rod coming from it, going in up towards the shaft.. there is a tear mark on it now and I think maybe I caused that when I now tried to install the new one.. with the pump arm connecting with that rod where the mark is and maybe thats why the pump broke...? Cant find anything about how to install the pump in the service manual.
Anyone got a clue as to what I'm doing wrong?
This is the new one I broke - http://gb.ioffer.com/i/fuel-pump-chrysler-dodge-plymouth-440-440hp-1970-1971-177961889
Bought new Holley pump.  - http://ecx.images-amazon.com/images/I/31Xi-BFYVZL.jpg
EDIT: NEVERMIND - found it here : - http://autorepair.about.com/library/bl217lib.htm
« Last Edit: June 26, 2011 - 11:06:29 AM by LukeSkywalker »
  • Plymouth
« Reply #72 on: August 09, 2011 - 08:49:51 PM »
Need help with the engines carb setup on a 440-6.
Can anyone here tell me where the three vacuum hoses on the carbs are supposed to end up?
They are all stuck together with T's but end up with a lose hose that I suppose should go somewhere.
Intake? Where the brake booster is supposed to go? Service manual is no help as it's all black pictures and I cant find anything in writing bout it either.
Any pictures that shows a correct setup of a 440-6 would be extremely helpful, as I have doubts about a few other things on it...
I see some setups have a hose from the valve cover breather connected to the middle carb, where my middle carb has a hose with a plug in it...
