Questions about my 70 Cuda...
Author Topic: Questions about my 70 Cuda...  (Read 19938 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
Re: Questions about my 70 Cuda...
« Reply #15 on: September 14, 2010 - 02:12:42 PM »
Yes there are: http://www.summitracing.com/search/Make/PLYMOUTH/Model/CUDA/?keyword=drum+to+disc
I myself use SSBC and they work fine. And fit under 14" wheel.
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline LukeSkywalker
  • Plymouth
« Reply #16 on: September 14, 2010 - 02:32:26 PM »
Thanks !
What does O.E. non-power and power mean?
"Drum to disc brake conversion kit with 4-piston cast iron calipers; power. Bolts to stock drum brake spindle. For O.E. non-power cars only."
Offline widing'cuda
« Reply #17 on: September 14, 2010 - 02:50:09 PM »
Thanks !
There are differnt spindels for cuda with factory disc brake and those with drums.
Some explaining in Norwegian:
Servobrems er power barkes. Har du tromelbremser ut bermskarft forstreker er det selvsakt noen power brakes. Er O.E. Originally Equited. Altså hva bilen kom med originalt.
  • Plymouth
« Reply #18 on: September 14, 2010 - 04:26:51 PM »
Skjønner. Thanks !
Offline 4Cruizn
  • HEMI FISH
« Reply #19 on: September 14, 2010 - 04:27:57 PM »
Ummm I think he explained it . . .
  • Plymouth
« Reply #20 on: September 15, 2010 - 11:52:43 AM »
Ftrrgeegljs dgdfgd gdksl dssdkjfs sdfosif ? Gkjsdhfsk shdfuydkn kljasdqqzx xiugd lkjhgs... Zkjyfewylfhgk diudfl lkødufgdi ølgkdøæ difgdkl ioertyzx.
Right? I know how that feels.
  • Plymouth
« Reply #21 on: September 17, 2010 - 12:52:55 PM »
Are there any books or service manuals for a 1970 Cuda? With wire-diagrams and such?
I'm kinda lost without one.
Offline dutch
« Reply #22 on: September 17, 2010 - 03:05:27 PM »
I got one off ebay.  a reprint of the original 1970 shopmanual.  Thick enough to beat a horse to death...
some pics are poor quality though. I think I payed like $ 60  or something.
*** Bart ***
  • Plymouth
« Reply #23 on: September 17, 2010 - 03:47:20 PM »
Thanks ! Bought the 1970 Cuda body manual book, the 1970 Wiring diagram book and the whole thing on a CD.
185$... If it's not there, it shouldn't be worth knowing..
« Last Edit: September 17, 2010 - 04:27:45 PM by LukeSkywalker »
Offline 73Chally
« Reply #24 on: September 23, 2010 - 11:16:34 AM »
You can buy complete kits from several aftermarket vendors, but your best bet will be to do some research on junk yard hopping to get used pieces for probably 1/10th the price of the aftermarket stuff.
  • Plymouth
« Reply #25 on: September 23, 2010 - 12:01:48 PM »
Thanks. Would a junkyard send to Norway though..?
Guess there is supposed to be a red line there since it's a Cuda. Did all Cuda (BS) come with the Rallye dash ?
Offline widing'cuda
« Reply #26 on: September 23, 2010 - 01:15:19 PM »
The rallye dash is an option that you had to order on all 'cudas. The aftermarket disc brakes are better than the old factory disc brakes. As they are of modern design.
  • Plymouth
« Reply #27 on: September 24, 2010 - 09:51:36 AM »
Where do I find axle ratio? Mine is a 489 but I cant see the ratio anywhere? Where would I normaly find it?
« Reply #28 on: September 24, 2010 - 10:15:47 AM »
you need to rotate the drive shaft & count the turns to get one revolution out of both tires if they turn at equal speed
  • Plymouth
« Reply #29 on: October 06, 2010 - 05:48:14 AM »
What are the hood wedges for?
Any one got a picture that show where they are supposed to go and their function..?
http://www.mopar9999.com/fcstore2008/images/228wedge.jpg
