Blinker problems-help
Author Topic: Blinker problems-help  (Read 4922 times)
Offline T/A Care
  • Pikes Peak Country
    • T/A Care's Website
« on: November 04, 2004 - 06:01:33 PM »
Here’s the prob:
A right signal flashes only the left rear.
A left signal flashes only the right front.
My 4 way emergency flasher flashes all lights, all corners.
All running lights are on with the headlights on.
I’ve replaced all bulbs and the flasher (and my blinker fluid is full too.  ;) )
Any suggestions? This has been a head scratcher…
Also, my turn signal cam in the steering column doesn't hold the signal arm in the left signal position very well. Any suggestions for a replacement?
Thank You Vets!
Visit T/A Care's Website
Romans 10:9-10
Re: Blinker problems-help
« Reply #1 on: November 04, 2004 - 06:24:54 PM »
T/A Care,
  I feel your pain. If you want to "PM" me, I'll tell you my tale of woe. I wish I lived closer to you because I love this kind of challenge. I guess there is no chance someone put(forced) the connector from the steering column on backwards? It's a ribbon cable. Maybe a bad turn signal switch?
Offline T/A Care
« Reply #2 on: November 04, 2004 - 06:33:21 PM »
Hey thanks Mike.  I'm headed out right now. I haven't figured out the PM here yet but I have an email icon on my post that you can shoot you "tales of woe"  ;) if you'd like.
Blessings and T/A Care,
Trip
Thank You Vets!
Romans 10:9-10
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #3 on: November 04, 2004 - 07:25:54 PM »
turn signal switch is bad or connector for the signals under dash from steering coloum has bad connections.
« Reply #4 on: November 05, 2004 - 01:44:58 AM »
I agree
Offline T/A Care
« Reply #5 on: November 05, 2004 - 10:31:54 AM »
Can you help me remember where the turn signal switch is please?  ::)  Is it near the blinker switch?
15 years ago when I lived and breathed the car I could probably have gone right to it! Thanks.
Thank You Vets!
Romans 10:9-10
« Reply #6 on: November 05, 2004 - 12:04:45 PM »
the turn signal switch is under the steering wheel inside the column , you do not need to cut the wires , the plug will slide through the column , it plugs in under the dash
Offline T/A Care
« Reply #7 on: November 05, 2004 - 01:10:22 PM »
Thanks Chryco.  Any suggestions on where I can get a new one?  Also, will it have any affect on my turn signal lever not staying in position?
Thank You Vets!
Romans 10:9-10
« Reply #8 on: November 05, 2004 - 06:07:20 PM »
Maybe this will help, or at least this dealer can. I have bought from him and he is a good fellow. Yes, it ill help your turn signal lever stay in position too ;) It is all cheap plastic that dry-rots over the years.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=34207&item=4501708918&rd=1
Offline T/A Care
« Reply #9 on: November 05, 2004 - 06:13:43 PM »
 Muchos gracias amigo!  I'll get in touch with the guy!
Thank You Vets!
Romans 10:9-10
« Reply #10 on: November 06, 2004 - 02:31:05 AM »
Standard in has the part , I can order through the local parts store, I rthink the  part # is TW-7
 you will have to disconnect the lever to replace the switch & when you install the new switch you can tighten the lever  properly
Offline T/A Care
« Reply #11 on: November 08, 2004 - 01:07:18 PM »
Thanks.  I'll check on it today.
Thank You Vets!
Romans 10:9-10
Offline Grancoupe
« Reply #12 on: January 03, 2005 - 05:08:00 PM »
Check your grounds.... Try using a seperate wire from the ground side of the battery and touch the housings that dont work.
« Reply #13 on: January 03, 2005 - 05:12:04 PM »
were you able to get it fixed ???
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #14 on: March 12, 2005 - 02:26:34 PM »
Check your local Chrysler dealer for these switches as well. Sounds like a bad switch for sure, plus you need one anyway to get a new cancel cam.
2013 Tige' RZR 343hp
