Author Topic: rear sway bar question  (Read 3494 times)
Offline priderocks
« on: September 10, 2010 - 12:54:47 PM »
I am adding an original factory rear sway bar to my 70 Cuda. It already has a front bar. I have all the original components except the sway bar links. Are the links used for the rear bar the same as for the front? Thanks.
Offline Challenger6pak
Re: rear sway bar question
« Reply #1 on: September 10, 2010 - 01:19:55 PM »
I believe that they are the same.  I ran into the same issue when I added a rear sway bar.  I just went to the local auto parts store and bought the urethene bushings that were mounted on the aftermarket link shaft and used them.
« Reply #2 on: September 12, 2010 - 12:44:33 AM »
Energy has universal links that will work for you
« Reply #3 on: September 12, 2010 - 06:08:25 AM »
  Rear are different but if you have modified the ride height you may need different length
« Last Edit: January 25, 2012 - 08:08:07 AM by Bullitt- »
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« Reply #4 on: November 29, 2010 - 10:48:48 PM »
I am presuming that most of you guys are in favour of the Energy Suspension products??    I just ordered the front end link kits from them with the polyurethance bushings.   Anybody notice a big difference using these over the stock setup?
Chaps
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
« Reply #5 on: November 30, 2010 - 03:14:49 AM »
the Poly are a stiffer bushing but still deteriorate over time
Offline chaps70rt
« Reply #6 on: December 04, 2010 - 03:59:13 PM »
Can the polyurethane bushings be greased??
Just curious..... CHAPS
440 - 4BBL - Shaker
Offline Cooter
    • christinecarclub.com
« Reply #7 on: December 04, 2010 - 04:24:56 PM »
Yes, in fact, they rec. it to keep the noises down..
Offline the_engineers
« Reply #8 on: December 05, 2010 - 12:06:20 AM »
Buy polygraphite...they're black and quiet.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #9 on: December 06, 2010 - 02:00:12 PM »
energy has a special grease about the consistancy of honet that works well & is recommended
Offline ChallengerHK
« Reply #10 on: December 06, 2010 - 04:17:11 PM »
I got that stuff at Neil's recommendation and it works great with noise reduction.
- Han Solo, Star Wars
