if you havent replaced or checked the thermostat i would . depending on the weather in your area i would run a 190 in somewhat cold areas 180 in desert areas , all depends on where you live , myop i like the 180 for desert areas lots of traffic and idle time / stock style radiator. 190 deg eng temp is where you engine makes the hp.
no pun intended but , why do people remove the fan shroud or try to run with out ? funny i run into this all the time when i goto shows . big aluminum rad BIG electric fans anlong with the car overheating .(all expensive parts installed and looking great BUT) put the ugly shroud and clutch fan and 2 row 26in rad and everything goes back to normal .
