Author Topic: hood scoops info  (Read 708 times)
Offline coupman35
  • It going to be FUN
hood scoops info
« on: September 12, 2010 - 08:21:19 PM »
Just like to no on a 73 challenger whit ralley hood ,the inserts that goes in the scoop are they just plain flat or are there like a grill like
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
wagesofsin
Re: hood scoops info
« Reply #1 on: September 12, 2010 - 08:32:08 PM »
theres a blockoff plate that screws in , not grilled. just flat plate.
Offline coupman35
« Reply #2 on: September 12, 2010 - 08:46:36 PM »
Thanks john it just a guy came over to have a look at the car and said  that i may not have the right plate in the scoop.I told him i check it out to try and see if there are the good one .I dont remamber seeing any out one then the flat one that i have in them .
wagesofsin
« Reply #3 on: September 12, 2010 - 08:48:33 PM »
i can make you the blockoffs if you want. ill take a pic tomoorow if it helps.
