Author Topic: Front and rear sway bars  (Read 10540 times)
Offline ChallengerHK
Re: Front and rear sway bars
« Reply #30 on: September 16, 2010 - 04:17:00 PM »
I had thought about welding the nuts on the inside. Might work. The biggest issue I see is that for a good, tight joint you need long, thin bolts, and the bolts holding the sway bar mounts are short thick bolts, just the opposite. They don't stretch as much, and bolt stretch keeps the joint solid.
- Han Solo, Star Wars
Offline cudazappa
« Reply #31 on: September 16, 2010 - 09:09:19 PM »
Other than reinforcing the inside of the frame rail (cutting it out, adding plate steel with holes drilled inside, welding it all back up for a seamless look) I don't see a really clean way to do it correctly.  When it's rear sway bar time for me (late winter) I'll just weld the brackets to the frame.  Won't pull off then!
2015 Dart GT - Daily Driver
« Reply #32 on: September 16, 2010 - 10:28:24 PM »
 :iagree: that was the conclusion I finally came to as well.
