Author Topic: 499 cube engine forsale  (Read 7442 times)
« on: September 14, 2010 - 06:59:18 PM »
I got a 440 source 499 I am wanting to sell to build a different combo.  I will try to get a picture of it tonight.   It has around 500 or less miles on it. But the heads are fresh , just installed 2 days ago. I went from 906's to hp 915's 214/181 valves , new springs, new guides,shaved .010 thou to be sure they were flat. I had the intake face cut  .015
440 source 4.15 crank, 440 source magnum pistons. Flat tops with valve reliefs, forged of corse, 440 source rods. I had it all balanced here.Crank is drilled for a 4 speed and bushing installed. Malie rings, race bearings, melling hv 63 hv oil pump, holds 75 running 35 idle, new hemi pan and windage tray, cloyles true roller 3 key timing chain, lunati solid 585 lift cam at 110 center, degreed in. pistons are  .012 in the hole with  .020 steel gaskets. I have no intake installed. HP fuel pump installed and electronic distributer set in time as it sets. Engine has 3/8ths push rods ball/cup. 440 source roller rockers 1.5 ratio  Engine idles at 800 cam pulls exceptionaly good from 2000 to 6200.  The engine block is  72 400 #230 block, bored to 4.375, All the engine needs is an intake and carb. I took the 6pk off.
If you want to know the exact bore, multiply
4.375 x 4.375 x .7854 x 8 x 4.15    this is 30 over to make a 499
Asking price 3k  negotiable    You can pm me here
Re: 499 cube engine forsale
« Reply #1 on: September 14, 2010 - 08:42:39 PM »
Great deal! :2thumbs:  This won't last long! If I was closer I'd be REALLY tempted ! :grinyes:
« Reply #2 on: September 14, 2010 - 08:51:28 PM »
I'll be in chatham tomorrow till sunday. Sorry I can't bring it with me for you :cheers:
« Reply #3 on: September 14, 2010 - 09:04:25 PM »
How big is your carry on bag?  :roflsmiley:
« Reply #4 on: September 14, 2010 - 10:39:26 PM »
I'm further north than Brad, but if I was anywhere near you I'd be driving over with cash in hand.
Offline cj
« Reply #5 on: September 15, 2010 - 07:11:27 AM »
Chatham, Ontario?  Cruise night is Thursday at the A&W on Grand Ave.
Cheryl
"Mopar or No Car"
1973 Challenger
1974 Barracuda
2006 Charger Daytona Torred
Offline BB73Challenger
« Reply #6 on: September 15, 2010 - 08:43:45 AM »
Thoughts on HP and torque?
Was thinking of building similar combo but with alum. heads... this could be a very priced right alternative  :money:
Oh also on comp ratio.  :wave:
« Last Edit: September 15, 2010 - 08:45:20 AM by BB73Challenger »
Jeff from Cleveland, Ohio
« Reply #7 on: September 15, 2010 - 08:46:04 AM »
Just a guestimate, but a solid 500 plus hp and 550 tq with the heads that is on it.
« Reply #8 on: September 16, 2010 - 05:59:56 AM »
One more quick off the top of my head, you mention race bearings... are they then suitable for street use or are they meant to only see so much run time before being replaced?
sleepychallenger
« Reply #9 on: September 16, 2010 - 09:04:57 AM »
sweet build Alan. Good luck with the sale!
« Reply #10 on: September 16, 2010 - 06:01:25 PM »
Radius rod and main bearings for clearance, full groove main bearings.....Thanks drew :2thumbs:
Offline mopar12372
    • mopartech
« Reply #11 on: September 17, 2010 - 01:13:38 AM »
yes -> they are better than stock -> hemi bearings
RESTO PICTURES
Offline ajantics
    • Yeah......Im a drummer!
« Reply #12 on: September 17, 2010 - 02:22:36 AM »
 :eek2: how can I get that motor shipped to the bay area??? That motor is sweet!
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #13 on: September 17, 2010 - 10:54:19 PM »
Guys this engine is INSANE, with new heads and more comp this thing will be even sweeter!
Alan floored his cuda with this engine in it and I could not pull myself off the seat the force was so great!
Alan great deal on this engine, as always you look out for the little guy and dont try to gouge anyone, you are a true mopar guy!  Thanks for all you do for us here.
Don
Member Since January 14, 2002
« Reply #14 on: September 18, 2010 - 05:55:25 AM »
thanks Don. I could maybe deliver this engine within a 300 mile radius for 50 bucks  zip 35055
