Author Topic: Header and bolt question  (Read 1162 times)
Offline daveh
« on: September 15, 2010 - 04:44:14 PM »
Hey guys I'm putting back together my 340 and have a couple of header bolt questions.  BTW I'm installing TTI headers.
1. I know I need to put sealant on the 4 outter bolts.  But if I do that when I go to retighten after start up won't that loosen the sealant?
2. I want to install stainless bolts and don't know if I should get the locking or regular stainless bolts.  What are your thoughts?
http://www.summitracing.com/parts/STG-8956/
http://www.summitracing.com/parts/ARP-444-1202/
http://www.summitracing.com/parts/PHP-21006/
3. Do you recommend the 12 point or hex head stainless bolts?
Any other thoughts you may have would be a help.  Thanks
Offline 72cudamaan
Re: Header and bolt question
« Reply #1 on: September 15, 2010 - 07:46:40 PM »
A good thread sealant wont harden up so you won't have a problem there. Either 12 pt or hex ( I assume you mean like an allen head) will work. As far as a locking piece , I would use a external locking star washer. A regular lock washer will gouge into the header flange and make it difficult to remove. Not to mention more of a chance of removing the ceramic coating.
If I cant fix it, it's broke
Andy  (phukker whither)
