Author Topic: proportioning valve  (Read 3169 times)
Offline rusty70cuda
proportioning valve
« on: September 15, 2010 - 11:07:12 PM »
I bought a 74 challenger that had this brake valve missing. Can  I get one from a different car? Satellite or a coronet? Anybody got a spare P/Valve for sale? Thanks Steve
sleepychallenger
Re: proportioning valve
« Reply #1 on: September 16, 2010 - 12:18:50 AM »
like i said in your other post, i got one from a 84 (i think) fury and it works good. If i were home then i would send you one of the extras that i have. other than that you can order them new from some company that name escapes me right now.
« Reply #2 on: September 16, 2010 - 06:24:01 AM »
I have the one off my 70 Challenger. But I don't think it's the same? I went with a wilwood adjustable one.
« Reply #3 on: September 16, 2010 - 09:18:48 AM »
one from a newer 5th ave / Caraavelle body should work or just install an adjustable one
« Reply #4 on: September 16, 2010 - 10:18:07 AM »
They are available new for around $95 but I've heard there are some problems with them.  I would think that a late B-body (Charger/Cordoba/Magnum)would use the same one.  I had an 82 Cordoba (J-body) that used the same valve as my 73.
« Reply #5 on: September 16, 2010 - 07:01:43 PM »
Unless your wanting it to be stock ?  I did this! Cheaper than $95 and I can adjust it if needed.
Offline tomsa
    • My cars in swedish
« Reply #6 on: September 19, 2010 - 08:05:59 AM »
Where can I buy that type?
« Reply #7 on: September 19, 2010 - 09:10:23 AM »
Just about anywhere that sells aftermarket performance parts....listing at Summit
Brand      Wilwood Disc Brakes
Manufacturer's Part Number      260-11179
http://www.summitracing.com/parts/WIL-260-11179/
« Reply #8 on: September 19, 2010 - 10:00:02 AM »
You do have to use the brake line ends provided .The stock ones are to big. Not a big deal just cut off one end and reflare
Offline tomsa
« Reply #9 on: September 19, 2010 - 12:18:22 PM »
Just have missed that model
Thanks
