you can install it two ways , Tee it in after the propeortion valve , block the second line out of the prop valve & lock the front brakes on & release the brake pedal to od a burn out or tie in into the rear line after the prop valve & lock the rear brakes off & hold the brake pedal on to lock the front wheels to do a burn out
