Author Topic: Distrubition block, Proportioning valve or both?  (Read 1321 times)
Offline 344speed
« on: September 16, 2010 - 12:54:45 PM »
Do these challengers come with both a proportioning valve and a distrubition block? Or one or the other? I ordered a new prop. valve and what I recieved was not what I had. Come to find out what I took off was a distrubition block. I have no recollection of the prop. valve. My 72 was 4 wheel manuel and I am putting disc on the front.
72 Ralley 344SPD
Re: Distrubition block, Proportioning valve or both?
« Reply #1 on: September 16, 2010 - 11:50:43 PM »
the factory prop valve has the warning light but an adjustable proportioning valve will do the same job without the factory valve
Offline 344speed
« Reply #2 on: September 18, 2010 - 03:10:01 AM »
Thanks. I think I am going to go with a stock piece though. If I am understanding correctly. The master cyl. with 2 chambers requires the proportioning valve. Yet mine had 4 wheel drums, a 2 chambered m/c and a distribution blok. Heaven only know though what was changed before I got it. I just am trying to figure out the way it should be with going to the disc brakes.
72 Ralley 344SPD
« Reply #3 on: September 20, 2010 - 03:08:16 AM »
the disc brakes require a proprtioning valve as well as a distribution block in 70 , after that it was one piece that did both jobs , you need a proportioning valve with a disc drum combo as the rears will lock up early without it
Offline 344speed
« Reply #4 on: September 20, 2010 - 10:54:01 AM »
Thanks Chyrco. Thats the one I got from inline. I thought it was the wrong one because it looked nothing like the one I had taken off. Thats when I called inline and they said what I took off was the dist. block. I did not know which one to put back on. I do now though. Thanks for the help! ;D
72 Ralley 344SPD
Offline heminut
« Reply #5 on: September 20, 2010 - 06:19:00 PM »
I've got disc front/drum rear with a booster and the later model aluminum master cylinder off of a Dodge van. I just ran a tee from the master cylinder to the front brakes and an adjustable proportioning valve on the rear brake line. I've never had a problem with this setup, and the brakes work great! Granted, there is no brake warning light with this setup, but I check my fluid levels regularly so it's not a problem
1970 5.7 Hemi Cuda
