Body higher on one side
Author Topic: Body higher on one side  (Read 3297 times)
Offline tomsa
    • My cars in swedish
« on: September 17, 2010 - 03:33:48 AM »
Finaly got the car on 4 wheels but noticed that passenger side is ~1" higher at the rear
I have :
  • new torsion bars in front
  • new rear springs
  • no rear shocks mounted yet
  • no engine and trans mounted
What can be the problem?  :clueless:
Re: Body higher on one side
« Reply #1 on: September 17, 2010 - 06:11:40 AM »
Once you install your rear shocks, engine and trans, then you can adjust your tortion bars for propper height. I don't see any problemsso far
Offline tomsa
« Reply #2 on: September 17, 2010 - 08:28:57 AM »
But it´s the rear that is higher on passenger side
Front end are ok and i can adjust it to correct hight later
« Reply #3 on: September 17, 2010 - 08:52:56 AM »
Rear reacts to the opposite front corner adjustment. Also when you assemble the suspension components it's possible to pre-load if the full weight of the car is not on them when you tighten things, this will work out as the suspension settles with use.
Offline ChallengerGary
    • Challenger Gary
« Reply #4 on: September 17, 2010 - 09:16:21 AM »
You have to remember basic physics - for every action, there is an equal and opposite reaction.
Basically the load that is being put on the front of the car by one of you torsion bars is causing the opposite side of the rear end to sit higher than the other.  Without your shocks and with no engine and tranny, there is nothing to equal out the torque that is being applied to the body.  Once you get everything settled in, then you will need to adjust the torsion bars to make the car sit level
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline tomsa
« Reply #5 on: September 17, 2010 - 09:21:49 AM »
Ok
Then everything is ok probebly
Just got confused because it was higher on one side but now I feel much more realaxed  :thumbsup:
Thx
Offline Aussie Challenger
« Reply #6 on: September 18, 2010 - 08:47:37 AM »
When I install new spring rubbers I leave the bolts loose, put weight of vehicle on them bounce the vehicle a couple times then tighten up shackles. The shockers don't make any difference to the height, they only control the spring oscillations.
In your case I would wait until the motor & trans are in and you have set the front up equally, to put your mind at rest I would make sure that the front is equal on both sides but it won't be exact until motor is in.   :working:   :cheers:
Offline Two74s
« Reply #7 on: September 18, 2010 - 12:38:31 PM »
Gladyou askedthe question. Just got done replacing shocks on all four corners.  And noticed the same thing. I will adjust the torsion bars and it should fix it.
Offline Road_Runner
« Reply #8 on: September 18, 2010 - 11:49:52 PM »
Did you put '4 speed' rear leaf springs on the car?  I know I've seen a couple of track-pak cars with the super HD rear leaf springs that the passenger side sat up just a hair higher due to the additional leaf springs on that side.  It could have been that this should have been adjusted out, but I remember hearing this was normal back then.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline tomsa
« Reply #9 on: September 19, 2010 - 02:40:21 AM »
I have P4452984 and P4452985 leafs on my car
http://www.summitracing.com/parts/DCC-4452984/
http://www.summitracing.com/parts/DCC-4452985/
"1970-74 E-bodies with 440 c.i.d. or 426 c.i.d. equipped with either manual or automatic transmissions"
« Last Edit: September 19, 2010 - 02:42:16 AM by tomsa »
Offline Road_Runner
« Reply #10 on: September 25, 2010 - 11:29:00 AM »
If yours is slightly higher on the passenger side it could be the reason.  The description says these were used on big block 4 speed cars which in my experience means extra leaf(s) on that side.  The springs on my Roadrunner are even bigger than these, I pulled them off a low mileage 69 Roadrunner in a junkyard in the mid 70's and was told they are Trakpak springs, and the Roadrunner sits higher on the passenger side as well.  Its not too big a difference, but its noticeable if you look closely.  Maybe an inch or two max.
Hopefully, thats all it is with yours.  I remember looking at a 72-73 Charger in the late 70's for a friend on a car lot and I pointed out the whole car was twisted!  It sat higher on the driver's rear and on the passenger front!  We passed on the car and he ended up with a Challenger RT with its own share of problems.
Later, Jim
Later, Jim
Offline tomsa
« Reply #11 on: September 25, 2010 - 12:00:26 PM »
Later, Jim
Later, Jim
It says: ".......with either manual or automatic transmissions" so I thought that was a good choise for a prepered 440" and aut
I will find out when the engine,trans,fuel tank and interior etc is mounted
Offline swede-cuda
« Reply #12 on: September 25, 2010 - 03:35:46 PM »
Offline swede-cuda
« Reply #13 on: September 25, 2010 - 03:39:37 PM »
Later, Jim
Later, Jim
:dunno:  is there any difference between track-pack springs and the extra heavy duty springs? :dunno: :wave:
Offline Road_Runner
« Reply #14 on: September 25, 2010 - 11:01:38 PM »
I only know that the springs on my Roadrunner are significantly thicker / heavier duty than the springs listed @ Summit.  I was told they were trakpak when I put them on the car around 1975-76.  The car they came off of was a 69 Roadrunner that the original teenage owner drove into an embankment at high speed when the car was new so most everything worth having was on the back half.  It was an original 440 4-speed car, the rear was already gone when I pulled the leaf springs.  So yeah, as far as I know the std 440 rear leafs were still not what was included in the Dana Trakpak cars, but I could be wrong.  If so, I have no idea why the RR's springs are so stout in comparison.
As far as yours being heavy duty enough, I'm sure they are.  You would not like the ride the RR's spring would give your E body, WAY too stiff for anything other than a 1/4 mile car.
Later, Jim
