Engine Mounts Question
Author Topic: Engine Mounts Question  (Read 3329 times)
Offline Challenger73
  • cfx_challenger
« on: March 28, 2002 - 01:10:29 PM »
Anyone know if I need to swap engine mounts when I swap a 318 to a 360 in my 73 Challenger?
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
73 Challenger, 318, 727, A/C, Non-Rallye
Offline Dark Horse
  • 70 Cuda ,69Mach 1,70 Charger RT/SE
Re: Engine Mounts Question
« Reply #1 on: March 28, 2002 - 07:13:22 PM »
bro, your be ok, only mounts that need a swap , woulb be if you were swapping over to a hemi!! all other mounts are interchangible.. sounds like a good upgrade! what mods if any are you doing to the 360?
When you see the Dark Horse...take heed
hell is coming to breakfast......
« Reply #2 on: March 28, 2002 - 11:46:25 PM »
Welcome
  Actually D H you are incorrect the 360 does not have the ears cast in the same place on 1 side of the 360 , I can`t remember for sure but I think the left mount is different between the 318 & 360 , you can also space the mount back approx 1/2" & it will line up ;) The K frame is the same for both.
Offline Dark Horse
« Reply #3 on: March 29, 2002 - 07:07:28 PM »
thats wild, the pn# for the mounts are identical  ??? I thought they would work..oopps sorry for bad info
Offline heminut
« Reply #4 on: March 29, 2002 - 09:12:59 PM »
Chryco is correct, the left one is different. Dark Horse, the part # you're looking at is the MOTOR MOUNTS, which are the same. Chryco is refering to the motor mount BRACKETS, the steel part that bolts to the block.
1970 5.7 Hemi Cuda
Offline Dark Horse
« Reply #5 on: March 29, 2002 - 10:20:41 PM »
right on, thanks heminut for clearing me up  ;) so for most engine swaps that are not hemi, are these brackets different like the 318 to 360 swap? so a 318 bracket is different than a 440/383??
« Reply #6 on: March 30, 2002 - 04:58:35 AM »
Yes ;)
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #7 on: April 06, 2002 - 05:07:07 PM »
???  Here I thought I was all set!? I'm about to make a 318 to 360 swap in a '73 Challenger and was told by a very reliable E body parts man that all I need to do was to take the 318 mounts and they would bolt up to the 360 block. I'm not sure now, and I sure hell would like to know before I sit that baby in her cradle. someone talk to me here!
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline BIG MIKE
« Reply #8 on: April 06, 2002 - 06:28:49 PM »
when i got my 72 challenger, they replaced the 340 with a 318. when i switched back to the 340, i had to put the bracket behind the ear of the block i believe. i know i used the same brackets without modifying or putting spacers in. i just moved the bracket. i will look monday
on my brackets but it will be late before i will be able to post.
« Reply #9 on: April 06, 2002 - 07:00:26 PM »
 I did a 318 -360 swap about a month ago & had to space the left monut back approx 1/2" ,this was the 72 style not the newer 73 up style
