Author Topic: Alternator  (Read 488 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
Alternator
« on: September 20, 2010 - 07:02:20 AM »
Could someone send me a pic of their alternator mounted to a non-a/c small block. I have 4 grooves on the crank shaft (2 slightly larger). I'm not sure how to mount the alt. because it is lining up with the power steering belt.  The water pump pulley also has 2 grooves. The top bolt of the alt is going into the head. I am wondering if I need a different crank shaft pulley because it was an ac engine.
