I was able to find the piece of paper that had a list of what was done to my motor. Now If this is whats really in it, I dont know for sure.
Manifold: LD340 and 1 inch spacer
Carb: 3310-2 holley 750cfm (wasnt on the car when got it now 750 Demon)
Distributor: Electronic accel parts
Coil: Accel super coil (Now MSD Blaster 2)
Lifters: ISKY anti pump up 3002
Push Rods: Norris Adjustable
Cam: Howard Racing 310 280 dur 465 Lift (thats the only spec i got on it)
Timing set: Cloyes True Roller
Cam Bearings: Clevite
Crankshaft: (custom), Balanced, Forged, and Shot peened. Also says something about chromoly journals polished, chambered oil passages?
Pistons: Speed pro .030 no2332
Connecting rods: Balanced, shot peened
Main Bearings: TRW clevite 77
Rod Bearings: TRW clevite 77 (CB481P)
Oil Pump: High Volume Direct Connection
Rings: Racing Custome
Oil Pan: Chrome 5qt
Connecting rod bolts: Direct connection High Strenght
Heads: 360 port matched, polished
Valves: Speed Pro 2.02int 1.65exh
Fuel Pump: electric Mallory
Retainers: Norris Titanium
Valve Springs: Isky
Valve Guides: Bronze walled.
Also Have some numbers on the back of the paper but I dont know what they mean except for the VIN number.
Head ID #1611
Block ID # 5630 31210257
Vin# JS23H2b20****
