Author Topic: need help for decode a build sheet  (Read 2285 times)
Offline JH23
« on: September 20, 2010 - 01:11:19 PM »
i need some help for a couple code on the buildsheet of the V code cuda of my friend.
in the wheel section i can read this code
wheel      wh cov
 8672         41
Alaskan_TA
Re: need help for decode a build sheet
« Reply #1 on: September 20, 2010 - 01:27:31 PM »
Skip down to the bottom line, what is the sales code in the W section?
Offline JH23
« Reply #2 on: September 20, 2010 - 01:40:53 PM »
in the W section, wh/cov section...
no code..... blank....
Alaskan_TA
« Reply #3 on: September 20, 2010 - 02:36:42 PM »
Steel rims with hub caps then.
Offline JH23
« Reply #4 on: September 20, 2010 - 02:55:47 PM »
ok and the lugage rack section M iu have a number in the case of lugage rack in section M . it mean the car is  born with luggage rack?
Alaskan_TA
« Reply #5 on: September 20, 2010 - 03:00:42 PM »
I could not find anything for the wheel numbers you posted, so the sheet may have a printing error? They are pretty common.
If you have a scan of the sheet you can email to me, I can look at it & go over the whole thing on the phone with you if you like?
Offline JH23
« Reply #6 on: September 20, 2010 - 03:03:42 PM »
ok and for the luggage rack??
also how i can see if the car is come from the factory with shaker hood? the v code cuda come standar with shaker llike hemi cuda?
Alaskan_TA
« Reply #7 on: September 20, 2010 - 03:09:44 PM »
First I think we need to establish if there is indeed a printing error.
If the data got printed in the wrong boxes then it changes everything.
If it is a '70 then the data may have been printed on a 1969 sheet as well, those can be very confusing & it happened fairly often.
Alaskan_TA
« Reply #8 on: September 20, 2010 - 03:15:56 PM »
[wheel      wh cov
 8672         41
[/quote]
You do have a '69 sheet, no wheel box on a '70 sheet, they say "wheels" - plural.
That will make this tough.
If he has not done so yet, have him check for more sheets. He may find another one or 4 printed on the correct form.
Offline JH23
« Reply #9 on: September 20, 2010 - 03:17:34 PM »
okk i understand.
how can i know if the sheet is a 69 or a 70 sheeT?
Offline JH23
« Reply #10 on: September 20, 2010 - 03:19:35 PM »
ok so i have a 69 sheet .. i can't base my research on the this broadcast sheet.. all the info on this sheet are wrong if i understand ?
Alaskan_TA
« Reply #11 on: September 20, 2010 - 03:22:30 PM »
Top left, you will see a revision date. 4/69 maybe?
It does not have a luggage rack. (At least not where you looked.) Line 9, 17th box from the left is for luggage rack on a '69 sheet. Same place on a '70 sheet is M21 - Drip rail mouldings.
Alaskan_TA
« Reply #12 on: September 20, 2010 - 03:24:51 PM »
Assuming the VIN on it matches the car it was found in, the data is correct for the car.
It is just on the wrong form.
The trim box is in the same spot on both versions, so the folks building the seats could get by just fine using the old forms, it was a great place to use up the leftovers.
Offline JH23
« Reply #13 on: September 20, 2010 - 03:28:48 PM »
ok so
on the luggage rack box i have a number. so if i have a number in this box it is the car is born with it?
and for the shaker hood ? if the car is born with shaker hood, i will see it on the fender tag? what is the code for the shaker? or i will see it on the broadcast sheet?
Alaskan_TA
« Reply #14 on: September 20, 2010 - 03:32:14 PM »
This would be a lot easier if I could see exactly what you see......
N96 is the code for the Shaker, it will be on the tag & sheet, but it will not be in the right spot on this sheet.
