Author Topic: 215 or 225 radials  (Read 3185 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
215 or 225 radials
« on: September 21, 2010 - 04:48:48 AM »
I'm looking at getting some bf goodrich radial t/a tires for the front.  What size is closest to F-70's?  215's or 225's?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Re: 215 or 225 radials
« Reply #1 on: September 21, 2010 - 09:03:34 AM »
  Chart shows 200/70-14 to be the most equivalent 14", 205/70-15 for 15".
...I'd go with 225 if you can find or wider if your rims are wide enough, 60's look better in the wider tire.
http://www.turbinecar.com/tires.htm
« Last Edit: September 21, 2010 - 09:07:13 AM by Bullitt- »
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: September 21, 2010 - 09:09:57 AM »
I've never heard of F70's before, what were they on? They would be a 235 70 15 (assuming a 15 inch wheel). I have heard of F60, which are a 235 60, and E70 which is a 225 70, but never a F70.
1996 Dodge Viper GTS Coupe
« Reply #3 on: September 21, 2010 - 09:28:29 AM »
Check out the link I posted...Tire sizing has evolved over time, when our cars were produced the letter represented a width (wasn't very accurate) & the number, as it does now, represents the sidewall height as a percentage of the width.  F70-14 was the size my '73 Rallye came with
« Last Edit: September 21, 2010 - 09:31:38 AM by Bullitt- »
Offline 72hemi
« Reply #4 on: September 21, 2010 - 10:02:27 AM »
True the letter represented the width and from what I have seen E equates roughly to 225 F to 235 and G to 245. That's why the common replacement for a F60 15 is a 235 60 15 or a 225 70 15 for a E70 15, now with 14" rims the letter may represent a narrower width, I've only had experience with 15"
Offline hooD
  • detroit iron
« Reply #5 on: September 22, 2010 - 05:03:08 AM »
I found some BFG tires that are 215-70-14 radials.  $90 each.
F70-14" Goodyear factory tires.  picture from March 1973
« Last Edit: September 22, 2010 - 05:13:12 AM by hooD »
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline 72hemi
« Reply #6 on: September 22, 2010 - 07:56:33 AM »
That is a really cool photo.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #7 on: September 22, 2010 - 09:34:16 AM »
 :iagree:  Nice pic, Hood.
Just for illustration purposes, I have 215/70-14 up front and 225/70-14 in back to give it a staggard look....also because that's what I had around the garage, works for me.  Sometimes in pics the 215's look a little small.  In the '72 Challenger brochures the front tires look bigger so I always wondered if the front/rears were bigger than 215.  :dunno:
More pics here: http://www.cardomain.com/ride/456046
From the back 3/4 view you can see the difference in the width of the tires.
See how the front look a little small in this pic:
225/70r-14 on the left, 215/70r-14 on the left
