Author Topic: Fuel Line Routing  (Read 2301 times)
Offline eastcan
Fuel Line Routing
« on: September 21, 2010 - 06:47:48 PM »
I am trying to connect up the hose from my fuel tank sending unit (3/8 supply, 1/4 return) on my 74 Challenger with California Emissions Package and need some help on the routing.  How does the 1/4 return on the sending unit connect to the vapour recovery unit (one with the 5 outlets located next to the tank)?
Re: Fuel Line Routing
« Reply #1 on: September 21, 2010 - 08:49:52 PM »
Does your '74 use the same vapor separator in this '73 (pictured) mounted on the shock member?
If so there are 4-corresponding nipples on the tank & the line to the engine bay goes to the 5th on top.
« Reply #2 on: September 22, 2010 - 02:28:45 AM »
the later cars never had the 3/8 sender , the 1/4" return on the sender was originally connected to the the vapor seperator on the pressure side of the fuel line between the pump & carb
Offline TROUBLE987
« Reply #3 on: September 22, 2010 - 02:11:33 PM »
Do you really need to use the vapor seperator?I asked the question once but cant remember what was said..
« Reply #4 on: September 22, 2010 - 06:01:31 PM »
Unless your connecting it to the charcoal canister & that to the carburetor vacuum no.
Otherwise it makes a simple vent for the gas tank.
