Which SFI approved bellhousing?
Author Topic: Which SFI approved bellhousing?  (Read 1098 times)
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
« on: September 22, 2010 - 05:08:18 PM »
Hi guys.
Im looking at a bellhousing to bolt up my 23 spline box to 440 with 130 tooth flywheel,in my 70 challenger.
It looks like either the lakewood or quick time housing.
Has anybody used either of these and are there any advantages other than the lakewood being $50 cheaper?
Thanks. Pete
Re: Which SFI approved bellhousing?
« Reply #1 on: September 23, 2010 - 01:07:58 AM »
I have never used a QT housing , make sure you get offset alignment pins & adjust for center with the new belhousing
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #2 on: September 23, 2010 - 05:26:19 AM »
I used the q t I think it's a little smaller in the tunnel area than the Lakewood it's a good product.  :2thumbs:
Go Fast & Have Fun...
Offline vinb
« Reply #3 on: September 23, 2010 - 09:01:10 PM »
The Quicktime looks like a nice piece. If I get a scattershield it will probably be that.
The Lakewood is big and alot of problems fitting from what I hear...
Offline punisher72
« Reply #4 on: September 24, 2010 - 01:42:31 AM »
I know someone that bought a q t housing but hasnt fitted it yet,and a guy has a lakewood housing and only had to die grind the id of the bearing retainer opening for proper fit. The lakewood is a lot bulkier as it can take the 140 tooth flywheel as well. I didnt think of the offset dowel pins? I would assume it to be a good fit? Cant hurt to be too carefull i guess.
Offline bigblue73
« Reply #5 on: September 24, 2010 - 08:41:07 AM »
Both are very good products - As mentioned the Lakewood is much larger in containment than that of the QuickTime.  This can cause issues with headers, especially TTI units.  The QuickTime bell housings are made from metal spinnings and are very accurate.  The Lakewood is Hydroformed.  I recommend the use of RobbMC offset dowels. (about $50.00) to dial indicate everything into place.
If you have any questions regarding QuickTime, don't hesitate to call Ross (owner of QuickTime).  He's a great guy and he stands behind his products.
Tony Edler
Hurst Driveline Conversions.
Offline punisher72
« Reply #6 on: September 28, 2010 - 06:53:35 AM »
Thanx for that Tony. I will go the QT... Ive decided to work my diff first so i can go launching  :burnout: :2thumbs:
