Author Topic: Gran Coupe in WA state  (Read 91944 times)
Offline EB3-GranCoupe
  • BP23 U0B
Re: NOOB from WA state
« Reply #240 on: May 18, 2012 - 01:16:20 PM »
Good job!!   :clapping:
Offline GranCuda1970
« Reply #241 on: May 31, 2012 - 12:11:00 AM »
Got the old bumper back on.
Offline TUNISCO
« Reply #242 on: May 31, 2012 - 12:52:28 AM »
Getting close. Are you gonna be ready for Mopars at the Ridge in Shelton June 23-24?
It would make a nice maiden voyage topped off with a parade lap aroud that beautiful road track!
« Reply #243 on: May 31, 2012 - 01:04:25 AM »
Maybe !! Still got a bunch to do Hope to run her this summer. She will be a 10 footer on the outside this year but a sleeper on the inside. :burnout:
« Reply #244 on: June 05, 2012 - 12:54:01 AM »
Decided to go edelbrock too much mods for holley set-up Eddie goes like stock!
Carb hooked up with accelerator smooth action.
 :bigsmile:
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #245 on: June 05, 2012 - 11:13:20 AM »
Looking good!  Sure--you can make it run this summer--if we get one that is.
The Brewmaster
« Reply #246 on: June 05, 2012 - 11:59:33 AM »
Yes she will be running pretty soon, I just need the fuel pump to carb fuel line for a carter style carb,(will track that down soon), need a plug for the drive shaft, ( input end it leaks a bit, the shop did not put one in ) , plug and attach all the wires, buy a manual choke cable since it is a manual choke carb, fork out the dough for a new or try to track down a used clutch position sensor for the pedal, buy a new battery, install the seats, buy the heater hoses and install the radiator and clutch fan, install the accurate exhaust ,run the oil pump with a drill to prelube, and fire her up. Then I will install the windsheild, grill, and fenders.  :eek4: There is a light at the end of the tunnel I just hope it is not a false summit in this climb and all goes well.
  • BP23 U0B
« Reply #247 on: June 05, 2012 - 12:12:25 PM »
now it gets exciting, and scary, at the same time!  good choice on going with  the carter clone edelbrock carb.  i think yo will like it better than a holley.  what's the cfm?
« Reply #248 on: June 05, 2012 - 12:18:37 PM »
750 ish cfm I will work on her some more tonite and all day saturday get allot done when i have the whole day. I comes and goes in spurts of adrenaline.  :bigsmile:
« Last Edit: June 05, 2012 - 12:21:45 PM by GranCuda1970 »
« Reply #249 on: June 05, 2012 - 12:26:16 PM »
My father in law Paul has helped me alot and guides me through the uncharted territory.
« Reply #250 on: June 06, 2012 - 01:28:58 AM »
Got the wiring mostly hooked up! ..and the rear sway bar is on.
« Reply #251 on: June 06, 2012 - 02:04:35 AM »
also got the green speedo gear in the tranny for the 15 inch tires and 3.91 rear pulled the tiny black one out.
  • BP23 U0B
« Reply #252 on: June 06, 2012 - 12:53:15 PM »
i think the stock carter is 850cfm, so you should be ok.  are you going with rallye wheels?  those red drums will look good peeking out through the wheels! is your rear sway bar from Firmfeel?  that's where i got mine; made for a simple install, and you'll like that it makes the car handle a whole lot better!
« Reply #253 on: June 06, 2012 - 07:38:14 PM »
I have welds on the tires now not sure what i will do in the future probably custom rallye. The rear sway bar is a origional unit off of another cuda purchased from a craigslist add. I got lucky the origional owner had sold all of his Cudas and that was the last part he had left from them in his garage. only paid 40 bucks and not pitted.
  • BP23 U0B
« Reply #254 on: June 06, 2012 - 08:53:18 PM »
good deal on the sway bar!!  other than paint, and tranmissions, our cars are twins!!
i like the rallye's, but i have a set of miniltes that i want to put on.  i just have to save up for the rubber.  AFTER i save up for the new rear chunk!  you are gonna have a blast when you get it fired up!!   rock and roll!
