1970 F 440 Hp with forged crank. From his ebay add: The engine is painted in it's original street Hemi orange , This is a FORGED STEEL CRANK engine. It's complete from carb to pan. Built with only the finest parts. Up graded forged Keith Black pistons .030 over, with speed pro molly rings. ( I NEVER bore a big Chrysler block more than .040 for street use, They sometimes run HOT.) The rods were resized and fitted with ARP rod bolts. The complete rotating assembly was balanced. A New Hydraulic cam and lifters with double roller timing chain and gears were also installed. A complete 3 angle valve job with hard seats for unleaded gas was given to the stock castings along with the factory correct valve covers. Fresh off the test stand and ready to drop into your car. It will include the upper and lower pullies with new fan belt, as well as a new fuel pump , water pump front case housing and new aluminum Hi volume water pump. Also included is a new alternator and all the factory correct mounting brackets that go with it. You also get the spark plugs and wires along with an Accell super coil. Everything you need to plug and play. The engine will also include a NEW Edelbrock 4 bbl. carb, or Holley
He is a prety cool guy nice to talk to and is selling another e-440 block right now and said he may want my 69 block to build. nothing but 100% feedback rating from his ebay store.
