Author Topic: Idle Problem On New Engine  (Read 1154 times)
Offline AMXguy
« on: September 23, 2010 - 10:33:46 PM »
OK I give up. this is the 3rd engine I've built to the same excact specs and others have been wonderful.
 I have a 440 six pack, six pac cam, 10.1 compression, mopar performance electronic ignition EVERYTHING is brand new and untuned .
 I started it up to break it in and it poped a few times buy took off and right away I put it to 2100 rpm and set the timing to 38 degrees. I ran it for a half hour and all looks perfect, it seems to run a little nervous , not as smooth as it should. vacuum at 2100 is 17 inches. so I bring it down to set the fuel mix and check the initial timing and it wants to die. if I take the timing below 25 or the idle below 1100 it stumbles around and dies.
 If I rev it up hard it responds very nice, run it up to 3000 or so and close the throttle and vacuum climbs to about 22 I think. I can tell how it kicks the started initial is a little high but anything less won't cut it. on break in I checked all the exhaust ports and they ran from 550 to 900 degrees. since it won't idle I messed with the mixture and richer is definetly better but I can't cure it with that, and it won't idle down low enough to know for sure.
 My thoughts are a vacuum leak or could my adjustable rockers be a little loose? I can hear a slight top end noise but not bad. I jetted down one size and went on size less on the power valve just as I did on my last build, could it be too lean? I see no soot in the exhaust tips.  I really really can't imagine a leak but I'm stumped. any and all ideas welcome.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline barracuda7199
  • needs a resto but having to much fun right now
Re: Idle Problem On New Engine
« Reply #1 on: September 23, 2010 - 10:47:58 PM »
sounds like a vacuum leak thats a big swing in exhaust temps. i would double check the carbs vacuum ports then check the intake gaskets give the bolts a another pull see what that does.
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline AMXguy
« Reply #2 on: September 23, 2010 - 11:10:22 PM »
I pulled all the easy plugs and #4 was a little dark, #2 was off white and the others were light chocolate, I'm not sure if that means anything or not on a break in.
 I did turn the outboard carbs down to just 1/2 turn open on the idle mix, it seems they're always too rich but is there any chance that could be a problem?
 I used one fiber gasket on top of a new valley pan, everything seemed to fit well. everything is tight. I know the intake could be leaking but I find it hard to imagine as well as it went on.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #3 on: September 23, 2010 - 11:46:29 PM »
it could be that the vacuum is too low to keep the power valve closed |& is flooding at low RPM or the power valve could just be bad
Offline AMXguy
« Reply #4 on: September 24, 2010 - 12:06:41 AM »
The idle vaccum on the others was around 12 inches, so I put a 5-6 power valve in. all new carbs too.  it did pop back a few times on start up but the new carbs are protected right? if I let it get below 1000 rmp the vacuum drops to zilch, of course the engine is in the process of dying at that point.
 Is the white plug a sign of anything? I've never checked them until I drove a while.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #5 on: September 24, 2010 - 03:14:00 AM »
white plugs are too lean , you need to increase the jetting
you also may needs smaller air bleeds to get it too idle properly , wire can be inseeted into the air bleeds to help it idle
Offline AMXguy
« Reply #6 on: September 24, 2010 - 09:55:52 AM »
But how can you explain only some plugs being white? even though I doubt it could that mean a vacuum leak? I have the jetting excatly the same as my other engine which is a twin, while I know that doesn't mean it's perfect for this engine I can't imagine it being way off.
Since I can't get it to run decent below 1300 rpm I'm wondering how to check for a vauum leak, would the starting fluid method even work at that speed?
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #7 on: September 24, 2010 - 10:25:57 AM »
if you have a dual plane intake & 1-7-4-6 or 3-5-2-8 are all white then one side of the carb is not working correctly
Offline AMXguy
« Reply #8 on: September 24, 2010 - 10:54:26 AM »
No, # 4 is dark brown and #2 is white.
 Maybe I'll pull the distributor and ECU off my Challenger and eliminate them as the problem. I have a feeling it's in the induction side of things but the fact I need 20 degrees of timing to keep it running at all makes me wonder.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline AMXguy
« Reply #9 on: September 24, 2010 - 12:52:00 PM »
I swapped dizzy and ECU with my Challenger and no change.
It almost has to be carburation or a vac leak. I did notice when I got it idles down to about 110 which is as low as it would run for a bit there was a little backfiring going on. nothing serious but you could hear blooping out the tailpipe.
 since the carbs are all new and jetted with a proven setting I'm at a loss as to the next move. I'd just hire someone to figure it out but nobody around here is anymore savy than myslef on this kind of set up.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline AMXguy
« Reply #10 on: September 24, 2010 - 01:52:22 PM »
OK it seems the problem is a vac leak under the right side of the intake, I'll move this to another thread.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
