Author Topic: Need a new oil pan.... any thoughts?  (Read 3289 times)
Offline blk440cuda
« on: September 26, 2010 - 09:10:05 PM »
My oil pan just lost a fight with a manhole cover (long story).  I had a Milodon deep sump, but it came straight down from the motor.  These seem to be my choices and I'm leaning towards dropping the extra money to get the one with the most clearance (31580).  Any thoughts???
http://www.summitracing.com/parts/MOR-20760/
http://www.summitracing.com/parts/MIL-30930/
http://www.summitracing.com/parts/MIL-31580/
http://www.summitracing.com/parts/MOR-18760/
Offline black71
  • eph 6:12
Re: Need a new oil pan.... any thoughts?
« Reply #1 on: September 26, 2010 - 09:32:13 PM »
http://store.440source.com/Oil-Pans/products/54/
bought the black deep sump..havent been able to try it in the car but seems like a good piece for the money..i know a lot of folks here arent fond of 440source, dont blame them
Offline autoxcuda
    • Spring Fling
« Reply #2 on: September 27, 2010 - 02:59:28 AM »
You've got to run a shorter pan than you are running now or you will just be in the same situation again.
Get the Milodon 7" street pan or the Milodon 31580. The Milodon 31580 is a sweet piece with lots of trap doors gates and such to keep oil around the pickup. Many people buy that pan to get more capacity and have a pan that is stock depth that will live on the street. It's shorter than the Hemi pan even!
Is there any reason you are running a deep sump or feel you need a bigger pan?
The street hemi 6 qt pan could be a economical compromise: http://www.summitracing.com/parts/MIL-30761/
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: September 27, 2010 - 11:40:16 AM »
I got one laying around that I'll sell ya for 100 bucks.
Offline blk440cuda
« Reply #4 on: September 27, 2010 - 05:20:20 PM »
"Is there any reason you are running a deep sump or feel you need a bigger pan? "
I have had the deep sump on since I built this engine and I definitely want to stay with a deep sump.
As of now, I think ill choose between 4Cruizn's pan or the 31580 that has even more clearance.
Does anyone have that 31580???
Offline autoxcuda
    • Spring Fling
« Reply #5 on: September 27, 2010 - 06:59:08 PM »
I don't have that part number pan, but basically the same bottom end that used on many of thier road race pans.
Heres a more detailed pic of a 31580. It's a much more complicated pan than a drag pans. Trap doors even in the side pods.
« Last Edit: September 27, 2010 - 07:00:54 PM by autoxcuda »
Spring Fling XXX
April 22 & 23 2016
Offline mopar12372
    • mopartech
« Reply #6 on: September 28, 2010 - 02:43:52 PM »
just get a hemi pan with a tray and be done with it . holds 6 quarts what more do you need?
http://store.440source.com/1970-71-Hemi-E-Body-6-Quart-Oil-Pan/productinfo/200-1123/
RESTO PICTURES
« Reply #7 on: September 28, 2010 - 03:43:10 PM »
How does the Milodon 31580 pan fit with stroker cranks?
« Reply #8 on: September 29, 2010 - 02:26:50 AM »
I do not see a clearance issue with a stroker crank & the road race pan .
 I did have difficulties fitting it through the later 73-74 K frame though as the left engine mount has extra bracing on it
Offline autoxcuda
    • Spring Fling
« Reply #9 on: September 29, 2010 - 03:52:27 AM »
Didn't know the E-body K frame changed in 73-74. Or did you ad on the bracing?  Do you have any picture of the K-member. And pictures of the installation area that is it close. I will pass it on to Milodon.
Spring Fling XXX
April 22 & 23 2016
« Reply #10 on: September 29, 2010 - 10:58:08 AM »
4c could take a picture of the extra bracing on hic X member , personally I do not have a picture
