Author Topic: Gear ratio change, WOW  (Read 1487 times)
Offline 74chall
  • Mopar or No Car
Re: Gear ratio change, WOW
« Reply #15 on: November 10, 2004 - 07:30:34 AM »
NZ ,Mark a spot on the backing plate and the brake drum with a bright color on the inside of the wheel as if you were under it by the gas tank. .Now do the same with the drive shaft yoke. Mark a spot on the 3rd member housing and the yoke. Now in one revoulation( 1 rev. will be one full turn on the mark you put on your back plate/brake drum) count the number of turns the drive shaft yoke spins.  3 and a half drive shaft rotaions in one revoultion on the marks you made on the brake drum  would mean you have 3.55's.  patriot
lemonboy69
« Reply #16 on: November 10, 2004 - 10:17:30 AM »
Awesome Nick!!! Got any pics of the fried tires?!?! grinyes grinyes
I'll be running 2.94's to start out with (just to get her on the road), then I've got my 3.23 to swap in... MMMMM FUN!!! dogpile
LB
