I really prefer the idea of keeping an ammeter in my car instead of changing to a voltmeter (I may put in a separate voltmeter if I do any additional gauges). There are inductive/clip-on meters that do not require insertion into the circuit (even a shunt-type requires that inline presence). Such things are made, even for automotive use, but so far I have not been able to find a U.S. source, only UK, so it gets a bit pricey.
What I'm thinking of is taking the factory ammeter, gutting it, and replacing those guts with those from an inductive unit. Then the big wire would just run up to the ammeter, through a clip, and back down; no connections, no fragile meter throttling power (or overheating).
Found
this one on ebay... 75 amp range which will be good to go for me (not putting in a hyper-power stereo or huge alternator). So far I haven't found a domestic supplier (only one place listed the 30 amp units and they were out of stock with no schedule on resupply).
Depending on how big all the working parts are, this might be just the thing to keep an ammeter safely.
If anyone knows of a source for this gauge (or equivalent) I'd really appreciate hearing about it.
