Author Topic: R/T Hood  (Read 740 times)
Offline 340SIX
R/T Hood
« on: September 28, 2010 - 05:33:30 PM »
Need Measurements
1}R/T hood from center where the hood moulding mounts to windsheild edge?
2}The edge/side from where the moulding mounts towards the windshield should be the same as fender edge
{ie}Without moulding just hood it self
Are the edges at rear rounded some or pointed?
Re: R/T Hood
« Reply #1 on: September 28, 2010 - 08:28:47 PM »
Here's a bump.  I know everyone here mostly owns a CUDA   but this will help get some attention for you..
Offline Challenger III
Re: R/T Hood
« Reply #2 on: September 28, 2010 - 08:56:57 PM »
I know everyone here mostly owns a CUDA.
  :lol:
I am showing 64" from the rear edge to the front edge running down the center of the hood. There is a sharp roll at the back edge - not "pointed". Same edge as the "windshield edge" of the fenders. When the fenders and hood are all aligned, the back edges and the front edges should match.
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline 340SIX
Re: R/T Hood
« Reply #3 on: September 28, 2010 - 10:38:20 PM »
Thanks I have a repro bolt on ASC&P T/A hood and wanted to make sure.
It was pined with 4 pins before on what was used as a race car who needed a taller hood. Had it since 2005 and just getting around to it again now.
So I closed up the rear holes and blocked it out, and wanted to do all major work so I could fill the low spots.
I also Media blasted the underside to get the paint off that as well.
The only other hood I have is a glass R/T bolt on hood that was on my now parted out 71 since 1984
I cut the crappy scoops that came with it back then made a ledge for the factory scoops to be installed. And then added a factory section of metal cowl vents from a damaged parts  hood.
It was needed since motor would not fit under a stock metal r/t hood
It is not a hack job was done clean lol
http://i234.photobucket.com/albums/ee87/fast340six/Challenger%20Dash/Challenger%20Hood/hood4.jpg
http://i234.photobucket.com/albums/ee87/fast340six/Challenger%20Dash/Challenger%20Hood/hood2.jpg
You can see in this pic where I had to grind,glass closed the holes that were from the wide hood moulding that was on it in the past. And thena slight coat filler.
So I have no metal hood to go by and no fender here. Going to do both hoods and "Know" that they are done for later use
« Last Edit: September 28, 2010 - 10:43:44 PM by 340SIX »
Offline 340SIX
Re: R/T Hood
« Reply #4 on: September 28, 2010 - 10:46:10 PM »
Also restored 2 SE Type rear hood mouldings today, one was toast but looks great.
Will have to open them up a little and take a little thickness off each hood to install them.
Re: R/T Hood
« Reply #5 on: September 28, 2010 - 10:51:44 PM »
Just to let you know, the measurement I gave you was over a stock metal hood with the tape stretched over the bulge. Let me know if you need any other measurements (maybe from beneath the hood?).
