Author Topic: 383 Inlet Manifold  (Read 2143 times)
Offline XBRIT
  • hood blackout finished
383 Inlet Manifold
« on: September 28, 2010 - 07:47:07 PM »
I have nearly finished the build on my 72 Challenger and having carburetor problems. The motor is a rebuilt 1970 383, 727 tranny and a Edelbrock 1806 650 cfm and a mild cam. I anticipate use to be Cruising not dragging Their seems to be a vacuum leak in the carb, so I have returned it to Streetside for replacement.
While the carb is off I would like to know the forums opinion on my choice of inlet manifold, I have a Edelbrock Torker or a Offenhauser. The latter seem to be a smaller aperture than the carb.
Any input would be most helpful.
Cheers,
Re: 383 Inlet Manifold
« Reply #1 on: September 28, 2010 - 07:54:41 PM »
That offy is a spread bore manifold. Is the carb a spread bore?  If not, are you running an adapter plate for a square flange carb? It would leak at the flange to base if not.  I always prefer an Edelbrock over an offy myself. A street driver would like an edel dual plane. Your torker is a single plane and can take away some of your low rpm driving ability.
« Reply #2 on: September 29, 2010 - 02:28:57 AM »
I would use the torker over the offy , the Torker was decent even though it is a single plane intake
Offline Supercuda
« Reply #3 on: September 29, 2010 - 08:32:23 AM »
My choice would be the Torker with a 1/2", 4-hole spacer (wood or phenolic resin), to help get back the throttle response and low-end torque. That would work really well on a street engine.
Offline XBRIT
« Reply #4 on: September 29, 2010 - 11:02:15 AM »
Thanks for your help.... the 1/2" thk. 4 hole spacer, does that follow the hole pattern of the carb bores?
Cheers.
« Reply #5 on: September 29, 2010 - 11:03:14 AM »
yes , the 4 hole spacer lengthens to bores below the carb
Offline Road_Runner
« Reply #6 on: September 29, 2010 - 12:06:51 PM »
You didn't mention what rear gear or the stall speed of the torque converter you are running.  If stock, the rear is likely a 3.23 which will be OK with the Torker off the line but it will be its happiest at higher rpm.  Same with the torque converter, I think stock it was a 10.5 or 10.75" which you can power brake up close to 3000 rpm off the line.  I ran a torker on a built 383, stock converter & 4.10 sure grip Roadrunner and it ran great.  So if you're running otherwise stock trans & rear, your 383 will be happiest mid-range & up rpm-wise.
100% agree on your leak, I'll bet the carb was fine, the issue was your spreadbore intake.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline XBRIT
« Reply #7 on: September 29, 2010 - 12:42:18 PM »
The rear end is an 8 3/4  3.23 sg and a stall of 2200 to 2800.
Offline Road_Runner
« Reply #8 on: September 29, 2010 - 05:23:52 PM »
  Should be a great down the road combination, not brutal coming off the line but if you're not racing it who cares?  Plus if gas mileage matters at all, 383's can be awful thirsty with steeper gears.  I'm going to go with either a 3.23 or 3.55 in the Barracuda with the same torque converter as yours because I want a car I can drive more than just to weekend cruises.
Later, Jim
Offline XBRIT
« Reply #9 on: October 02, 2010 - 09:58:38 PM »
I have decided to go for a dual plane Edelbrock which I will make a purchase on next week. I really need low end torque to make it drivable in traffic.
This site is so good for the likes of folk like me with limited knowledge on these vehicles.
Thank you all.
Offline Strawdawg
    • Vortex Buicks
« Reply #10 on: October 03, 2010 - 01:02:39 PM »
If your converter has the stall you stated, I doubt you will tell much difference at all between the torker and the Edddy....
Offline XBRIT
« Reply #11 on: October 09, 2010 - 11:43:14 PM »
What is the torque spec for torquing down the alloy Edelbrock Intake Manifold? Also I had to Helicoil one thread.. no problem but when I snapped of the Helicoil fixing tab it fell down the bolt hole!!! will that be a problem??
Cheers,
« Reply #12 on: October 09, 2010 - 11:48:04 PM »
if the tab fell down the intake and it was installed    yes it will do damage. You have to get it out before you spin your engine over and suck it into the valve and piston.   about 35 ft lbs with a washer.
Offline XBRIT
« Reply #13 on: October 10, 2010 - 12:46:34 PM »
It did not fall down the intake, as the tab snapped of it when down the blind hole of the hole I was helicoiling.
Cheers,
