Author Topic: Young and in Love  (Read 4895 times)
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
Re: Young and in Love
« Reply #30 on: October 02, 2010 - 09:32:35 PM »
You will have a difficult time hearing engine ping with that exhaust leak.
I mentioned a vacuum leak earlier in this link.  I think that needs to be corrected before advancing your time and turn your dist.  If I were you, I'd turn everything back, get that paint off the h.balancer and correct the vacuum leak.  Then work the timing as explained above.
Of course, none of this matters with the exhaust leak.  I think you said that you have a 360 in there.  I have a pair of exhaust manifolds off my 360.  Otherwise, get a pair of those 1970 AAR exhaust manifolds ($300 on average).  If you think that converting your exhaust pipes back to except manifolds will be too much of a pain, then just find a USED pair of Dougs or TTI.  Paying for new ones would be a waste of money for your application.
Party on!
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Offline FinallyRearDrive
  • one lucky little SOB
« Reply #31 on: October 02, 2010 - 10:28:10 PM »
Thanks. Its a 383, so your manifolds wouldn't work, but that's a good idea to try to find some used pipes. I'll start looking. Are there any hot spots I should first look at for a vac. leak? or is it pretty much random where they pop up? I rebuilt the carb, and I don't know how old the dist. is (it had electronic ignition before I got it) so I don't konw how old the vac. advance or the lines are. Thanks in advance for the guidance.
« Last Edit: October 02, 2010 - 10:32:08 PM by FinallyRearDrive »
« Reply #32 on: October 03, 2010 - 12:47:49 AM »
I though maybe you had manifolds on the car now . the Only headers I can recommend are the 2 I listed , both fit the car well & have good plug clearance , cheaper ones can cause a multitude of problems , hitting anything , poor ground clearance & burning wires
Offline Aussie Challenger
« Reply #33 on: October 03, 2010 - 06:37:07 AM »
I know that TTi make a header set for the 383 which is different to the RB block headers.
Don't worry about the vac advance, get the mechanical working properly first, all tuning should be done with vac advance disconnected anyway and then if you want to have it connect and recheck idle.   :2cents:
