NZ's Part List (So Far)
Author Topic: NZ's Part List (So Far)  (Read 4077 times)
Offline Carlwalski
« on: November 08, 2004 - 01:48:00 PM »
Here is my Challenger parts list. So far anyhow. The numbers are the part numbers from Yearone.
Thought you guys might be interested to see the new parts and to also compare to what you have bought.
This list is for my Resto guys to let them know exactly what I gave them and what parts they have to use, and just for plain old fun to.
FRG10   Restoration gasket package, 1970-1974 E-body models with 8-3/4" differential-to-housing seal, reproduction.
LP7004   Door panel woodgrain vinyl insert set fits 1970-1974 Challenger.
CC7074   Door weatherstripping, 1970-1974 E-body models, reproduction.
CC3016   Roof rail weatherstripping, 1970 E-body models, reproduction.
FR232   Quarter glass weatherstripping, 1970 E-body models, reproduction.
JM634   1970-71 Challenger front/rear side marker lense kit, reproduction
J14RH   RH parking light lens, 1970 Charger and 1970-1974 Challenger models, reproduction.
J14LH   LH parking light lens, 1970 Charger and 1970-1974 Challenger models, reproduction
UD1   1968-1970 B-body under dash insulation.
DPC70338A3   Dash pad, 1970 Challenger with 3 speakers and A/C.
J24   Parking brake pedal pad bezel for 1971-1972 B-body and 1973-1974 E-body models with A/T.
J119   1970 E-body models accelerator pedal bezel.
J26   Parking brake pedal bezel for 1966-1974 B-body and 1970-1974 E-body models. Stainless steel.
R466   Back window centering clips, all E-body models, reproduction.
FWTE   Wiper transmission gaskets, 1970-1974 E-body models, reproduction.
J4S   Door end seals, 1970-1974 E-body models, reproduction
FD1289   Oil filter, late 1960s and early 1970s Chrysler V8 engines, new Chrysler.
AD1000   This set of 8 end link bushings fits front bars only on 1966-1969 B-body and 1970-1974 E-body models.
MG5001   1971-1974 B-body and 1970-1974 E-body sill plate screw set, reproduction.                      X 2
R77   Aftermarket strut rod bushing set includes 2 rubber bushings. Fits 1966-1972 B-body and 1970-1974 E-body models, use 2 per car.
RF468   Remote mirror retaining clip, 1967-1974 B- and E-body models, reproduction.                    X 2
FD292   Mirror mounting nut, 1970-1974 E-body models, new Chrysler.                                            X 2
P4120758   1966-1976 V8 B- and E-body models cooling fan
VC213   Fender emblem, 1970 Challenger R/T, reproduction.                                                            X 2
VC212   Fender emblem, 1970 Challenger models, reproduction.                                                      X 2
MY2   RH fender emblem, 1967-1972 A-, B-, C- and E-body models, reproduction.
FD40B   Hood emblem, 1970 Challenger 440 Magnum, new Chrysler.                                              X 2
FD100   Trunk lid emblem, 1970 Challenger models, new Chrysler.
VC742E   Back up lens letter set for 1970 Challenger.
RX43   Grille emblem and retainer set, 1970 Challenger R/T, reproduction.
VC155   Grille emblem, 1970 Challenger models, reproduction.
FD103   Trunk lid emblem, 1970 Challenger R/T, new Chrysler.
JM96   Trunk lid/quarter panel molding hardware set, 1970-1974 Challenger models, reproduction.
WR88   Body side molding retaining hardware set, 1969 GTX, reproduction.
FD7440   Wheel opening molding screw set, pre-1970 models, reproduction.
KT152BLK   Vinyl top, 1970-1971 Challenger and 1970 Challenger SE models, Boar grain material, reproduction.
NG01   Oil pan gasket, fits all big-block and 426 Hemi engines, aftermarket.
TL77   Tail lights lenses, 1970 Challenger models, reproduction.
FD170   1970-1974 2-door E-body sill plate. New Chrysler.        X 2
ED33840   1964-1974 B- and 1970-1974 E-body Performer IAS front shock, Edelbrock.                      X 2
ED34840   1964-1974 B- and 1970-1974 E-body Performer IAS rear shock, Edelbrock.                       X 2
JH101   Fuel tank pads, 1970-1974 E-body
AQ6   Fuel tank, 1970 Challenger models with E.C.S. 18-gallon capacity tank, reproduction.
BN145S   Wheel opening moldings, 1970-1974 Challenger models, reproduction.
HLJ8   Headliner insulation kit, 1970-1974 Barracuda and Challenger.
XA983   Seat foams, 1970 Challenger with vinyl seat covers, 1970-1971 Barracuda and Gran Coupe models with leather seat covers.
1FL70338U   Front bucket seat covers, 1970 Challenger, Challenger T/A and Challenger R/T models with Coachman grain inserts. Blue
SB3230L   74” universal non-retractable seat belts, for one passenger only.  Blue                                X 2
PJX70   Package tray padding, 1970-1974 Challenger.
PDY70MBL   Deluxe package tray, 1970-1974 Barracuda
DJE70   Rear seat/trunk divider jute padding, 1970-1974 E-body.
E91   Stock replacement oil pan, 1970-1971 426 Hemi, 1970-1972 440 (4- or 6-bbl) engines, reproduction.
FD99808   Oil pump pickup tube and screen, 1970-1974 440 engines, new Chrysler.
BG553   RH drum brake self-adjuster kit fits 1969-1974 B-body and 1970-1974 E-body models with 10" drums. Will work for both front or rear.
BG552   LH drum brake self-adjuster kit fits 1969-1974 B-body and 1970-1974 E-body models with 10" drums. Will work for both front or rear.
S103   Coolant recovery kit.
FR36405   Heater hose straps fits 1971-and-later B-body models and 1970-1974 E-body.
WR43   Spark plug wire bracket kit, 1970-1971 383/440 B-body and E-body models, reproduction.
E149   1970-1971 models P.C.V. valves.
FR3   Battery cable bracket, 1970-1974 E-body models, reproduction.
FW375   Hood pop-up spring, 1970-1974 E-body models, 1971-1974 B-body models and 1970 Charger/Superbird, reproduction.
FD9124   Oil pressure sending unit, all models with gauges, new Chrysler.
MC64   Positive battery cable, 1971 B-body slant-6 (except floor-shift M/T) and 383/440 V8 models/ 1972 B-body slant-6, 400/440 V8 models without air pump, 1970-1971 E-body slant-6 and 383/440 models, and 1972 E-body slant-6 models without air pump, reproduction.
MC88   Negative battery cable, 1970-1972 B-body 383/440 V8 models and 1970-1971 E-body 383/440 V8 models, reproduction.
A01210   Dodge "440 Magnum" air cleaner pie pan.
7074EBRB10   1971-1974 Barracuda and Challenger A/T or 3-speed column shift M/T models loop-pile carpet set.
FM687BRB   Dodge R/T floor mat set with embroidered R/T logo.
BBK10W   Body bumper kit, 1970 Challenger models, reproduction.
FD2949   Side-of-hood bumper, 1971-1974 B-body and 1970-1974 E-body models, new Chrysler.   X 4
JH304   Paint seal kit, 1970 Challenger models, reproduction
ES5209   Polyurethane bushing kit fits some models including those equipped with 440 and Hemi engines. Front spring eye bushing has diameter of 1-1/2" and includes 12 bushings and 2 sleeves, enough for one car.
WS103   RH threaded rear wheel studs fit 1958-1974 B-body and 1970-1974 E-body.
TG77   Tail lights lens gaskets, 1970 Challenger models, reproduction.
RJ986   1970 E-body models plastic pebble-grain acclerator pedal.
PPM22100   Pillar post molding, 1970-1974 Barracuda and Challenger.
1FL70100U   Front bucket seat covers, 1970 Challenger, Challenger T/A and Challenger R/T models with Coachman grain inserts.
1RL70100C   Rear bench seat cover, 1970 Challenger, Challenger T/A and Challenger R/T coupe with Coachman grain inserts.
R15   Sunvisor tips fit all B- and E- body models.        X 4
AH755100   Premier Perforated grain headliner, 1970-1971 Challenger with 5 bows.  Black
# 1970 Bucket Seats with Seat Tracks
# 1970 Automatic Console with New Console Lid Button
# 1970 Automatic Floor Shift Steering Column (Restored)
# Tilt Pistol Grip Shifter for Slap-Stik
# 4 15x8” Mopar Cop Rims  with 245/60 BFG Goodyear Tires and 4 Dog Dish Hubcaps
# MPBrakes kit. New Front Disc brake Package
# Tuff Steering Wheel
# Left and Right hand Lower Dash Pieces
# Drivers Side Window (Glass)
# TTI Headers & TTI Exhaust System with Dynomax Mufflers
# 2-1/2” Exhaust Tips
# Slap-Stik Indicator light Wire
# Trunk & Quarter Panel Moldings
# Head-Unit, Amp & 6-9” Speakers (x2).
 patriot
« Last Edit: November 08, 2004 - 01:51:12 PM by NZ 440RT »
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 74chall
  • Mopar or No Car
Re: NZ's Part List (So Far)
« Reply #1 on: November 08, 2004 - 01:57:15 PM »
INSANITY!  iagree
NOooooo  nono writing up parts list for me. I would go nuts thinking of all the $ and parts I bought! that is a big list! But whens its all done thats going to be ONE nice chally!
Offline Carlwalski
« Reply #2 on: November 08, 2004 - 01:58:40 PM »
Yeah I know, money sucks  laughing Most of my money goes on labor like 70% of it, so the parts list is my major concern.  wave
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #3 on: November 08, 2004 - 02:09:02 PM »
Wow NZ...amazing list.  Where have you been keeping all this stuff?  All our goodies took almost half our garage, but our stock is dwindling down now that we're getting it together.
Offline Carlwalski
« Reply #4 on: November 08, 2004 - 02:12:06 PM »
Thanks, on the deck, in my shed, in my bedroom in the hallway LMAO!! Basically where I don't get told to move it is where it goes.
Thats got to be the best part when it all starts to shrink and the parts all go back on.......ahhhhhhh can't wait!!  drool :D
Offline 4Cruizn
  • HEMI FISH
« Reply #5 on: November 08, 2004 - 04:13:27 PM »
Dammn Dude!!  That is one big list.  eekbig  eekbig   I'm sure if I kept track, my list would be just as big!  lol  You must have a good job 'cause I know parts cost just about as much as the shipping where you live!  That would SUCK!!  I bet that car is gonna be sweet!!   thumbs
« Last Edit: November 08, 2004 - 04:20:51 PM by 4cruzin »
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #6 on: November 08, 2004 - 04:24:54 PM »
That is one LONGGGGGGGGGGGGGG list when you first glance at it, but all in all, it doesn't seem too too bad.  I guess it could be worse.  Are you going to be doing any of this yourself or is it all for the resto guys to install?
Plum6Pak
« Reply #7 on: November 08, 2004 - 07:08:22 PM »
Wow,  :o  that is a long list, just about as long as my file for my project is thick!!! I started adding up things one day and once I saw how high it was getting, I put it away and decided it doesn't really matter anyway.  grinyes
Offline Carlwalski
« Reply #8 on: November 08, 2004 - 07:21:39 PM »
The list could be longer, but there are some really big pieces in that list and the hard to find expensive pieces are the list below which came from eBay or Tonysparts. Seats, Console and brackets, shifter, body side moldings (which will not be used be stored) etc  wave
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #9 on: November 08, 2004 - 09:47:03 PM »
It's scary to think of how long a list is. I just kept making 10 item lists as I needed them. But in your case I'm sure shipping would have been nutz!
Rev, I know what you mean about the garage space coming back. I'm in the process of making 3 piles of the leftovers now; 1)garbage 2)Swap meet 3) E-Bay.
2013 Tige' RZR 343hp
Offline Carlwalski
« Reply #10 on: November 08, 2004 - 09:56:01 PM »
Thats exactly what I have been doing. I have so many little note pads filled with parts etc..... grinyes
Offline RusTy/SE
  • Just havin' fun
« Reply #11 on: November 08, 2004 - 10:13:13 PM »
  I totally understand, NZ. I have a three ring binder for each car containing clear plastic pages - one page per year i've owned them. When possible i'll jot down the email address of wherever i received a particular part from so's i can email a finished pic to with my thanks.
tfn
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline Carlwalski
« Reply #12 on: November 08, 2004 - 10:23:27 PM »
Definitely.
I've got a photo album from start to present. A hardcase file with all the receipts, packing slips, confirmation emails, the specs, owners papers, and 3 pages of bills from eBay, Yearone orders, Tonysparts, resto bills (week 1, week 2 etc) with a brief description of what was done for that week and it also hold the VIN and fender tag, I wasn't going to leave that around there.  ack laughing ;D dupe
Offline Street_Challenged73
« Reply #13 on: November 08, 2004 - 11:52:42 PM »
Wow, that took a while to write NZ...All those parts, when put together, are going to look sweet!!!!! grinyes grinyes grinyes grinyes
Offline Carlwalski
« Reply #14 on: November 09, 2004 - 12:25:02 AM »
Thanks mate.  ;) But I've been writing them in a file in excel everytime I order and recieve a part(s). It's for me and the resto guys.  guitar
DANG!!!!!!! Check out all the smilies!!!!!!!!!!!  worship
