Author Topic: Notifcations  (Read 3981 times)
Offline Oldschool
  • Member Since 9-05-06
Re: Notifcations
« Reply #15 on: October 14, 2010 - 10:25:24 AM »
Kmyles,  I have looked over all your profile and everything looks like it should in order for you to receive notifications. I compared it to others that are not having issues and everything is the same. Not sure where to go from here....    :dunno:
Ken  --  In Georgia
Offline kmyles
Re: Notifcations
« Reply #16 on: October 14, 2010 - 01:09:30 PM »
this is getting crazy! :pullinghair: :banghead:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline kmyles
Re: Notifcations
« Reply #17 on: October 14, 2010 - 07:27:38 PM »
Someone must know how to fix this???
_________
Kevin
Offline Troy
Re: Notifcations
« Reply #18 on: October 15, 2010 - 10:41:47 AM »
Just out of curiosity, are they going into your SPAM folder? There's also a chance that your ISP is blocking emails from the site (this is usually dependent on how the mail server is set up). Someone with access to this server would need to verify that the emails are getting sent. They may also be able to tell if the emails are getting "bounced" - although some companies will just "blackhole" any emails that they think are invalid. Then it's up to you to bug your ISP until they fix things. Do you have another email address you could switch to temporarily (just to see if it solves the problem)?
Troy
Sarcasm detector, that's a real good invention.
Offline kmyles
Re: Notifcations
« Reply #19 on: October 15, 2010 - 01:09:02 PM »
Just out of curiosity, are they going into your SPAM folder? There's also a chance that your ISP is blocking emails from the site (this is usually dependent on how the mail server is set up). Someone with access to this server would need to verify that the emails are getting sent. They may also be able to tell if the emails are getting "bounced" - although some companies will just "blackhole" any emails that they think are invalid. Then it's up to you to bug your ISP until they fix things. Do you have another email address you could switch to temporarily (just to see if it solves the problem)?.
Troy
I checked all that, and it's just a hotmail acc so I don't think it's on that end that there's a problem
« Last Edit: October 15, 2010 - 05:53:33 PM by kmyles »
_________
Kevin
Offline Troy
Re: Notifcations
« Reply #20 on: October 15, 2010 - 04:54:13 PM »
Ok, just trying to cover all the possibilities.
Troy
Offline kmyles
Re: Notifcations
« Reply #21 on: October 15, 2010 - 05:58:08 PM »
Don't tell me I have to create a new username to get notifications???? What else is thre that I can try??? :pullinghair: :pullinghair: :pullinghair:
_________
Kevin
Offline kmyles
Re: Notifcations
« Reply #22 on: October 18, 2010 - 01:15:32 PM »
Come on guys...what do I do :stomp:
_________
Kevin
Offline Oldschool
Re: Notifcations
« Reply #23 on: October 18, 2010 - 01:32:43 PM »
I have looked at your profile repeatedly to find a problem and I can't see anything different than anyone else's profile. Not sure what to tell you to do from this point. If you decide to delete your user name and re-register, I can restore your post count. I can't tell you if that will help you or not....   :dunno:  Did you change anything before this issue began?
Ken  --  In Georgia
