Author Topic: E-Body and SB Parts  (Read 6597 times)
Offline smokinjoe
E-Body and SB Parts
« on: January 29, 2002 - 09:19:17 AM »
I have lots of stuff left over from my 71 Challenger restoration. Send me a list of what you need.
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Offline brian
  • I love YaBB 1G - SP1!
Re: E-Body and SB Parts
« Reply #1 on: February 03, 2002 - 05:41:41 AM »
I just bought a '71 Challenger. It's a318 2bbl auto with a slap stick. I know I will need alot of parts to restore it. As of right now I know I need a grill, outside door handles, sunvisors,headlight and wiper switches with pigtails, and possibly a gas tank. If you have any of these items could you send me the prices. Where are you located?
Offline Dark Horse
  • 70 Cuda ,69Mach 1,70 Charger RT/SE
« Reply #2 on: March 01, 2002 - 04:34:15 PM »
what size rear end and is it for sale???
When you see the Dark Horse...take heed
hell is coming to breakfast......
Offline dcknuth
  • I'm a llama!
Re:E-Body and SB Parts
« Reply #3 on: August 10, 2002 - 04:08:41 PM »
I am looking for the followinf parts for a my 71 cuda.  All parts that have date codes should have date in the feb-aug 1970 wherever possible.  Please let me know if you can help.
Description                          Type                Part #
Air Cleaner (Twin inlet original)    Original
AM Radio
Antanae Assembly
Battery
Belts/Hoses
Carb Rebuild
Carberator-Carter T-quad (AVS)       Original        4934 or 4937 or 4973
Distributor                                             3438325/3438517
Door Handles L & R
Drive Shaft
Exhaust Manifold                                         3418621/3418623
Exhaust System
Exterior Gasket Set
Fan Belt
Fan Shroud
Fan/Clutch                                                   2863216
Floor Mats
Front Bumper
Front Turn signals
Grovier Decode
Grovier Phone Consultation
Harmonic Balancer Pulley
Interior Screw Set
Jack
Master Brake Cylinder                                       3579272
Cylinder Rebuild
Misc. B.S.
Instalation
Side Window Wiskers  onees that fit into the body mouldings
Stainless Mouldings
   Door Top Edge Left
   Door Top Edge Right
   Lower Windshield Trim
   Rocker Mouldings L & R
   Rear Tailight Panel Turns L & R
   Rear Window Top Edge Left
TIRES/WHEELS
   Ralley Wheels 15" x 7"/Rings/Centers                    2944390
   Rings-Polished Aluminum
   Hubs                                                     3461352
Trim Rubbers
Washer Bottle
Water Pump Pulley
Black Lower Interior front kick panels
Sincerely,
David Knuth
(708) 946-2543
(708) 946-2067
Offline TreeFrog
    • TreeFrog
« Reply #4 on: August 18, 2002 - 10:03:30 PM »
I need the part that the radiator sits in and bolts to.
The lower tie bar, or lower core support, whatever it may be called
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline sixpackcuda
  • Six pack to go!!!
« Reply #5 on: August 18, 2002 - 10:17:04 PM »
Wow dcknuth, you buy a shell??
The top door moldings are different for the Challenger than a Cuda, I know from experience!!!
I'll have a lot of trim, emblems, console etc. when mine (IF) comes out of the body shop, most is good just bought new stuff since I was spending $8000. on the body.
Check with Laysons they will have most of what you need if Smokinjoe doesn't.
www.laysons.com
Yeah how about that rear??
[attachment deleted by admin]
« Last Edit: August 19, 2002 - 01:17:08 AM by sixpackcuda »
http://www.sixpackcuda.us
In-Violet 70 Cuda 340 W/6 Pack
Mopar Rules!!
IF IT DOESN'T WEAR A STAR, IT'S NOT A REAL CAR!!
Offline badfish
« Reply #6 on: August 20, 2002 - 09:46:16 PM »
  Is the windsheild moulding the same as aCuda?? If so and you have one, I am interested. Thanks
Offline sixpackcuda
  • Six pack to go!!!
« Reply #7 on: August 21, 2002 - 01:20:11 AM »
The window trims are the same, I will have an extra set of both, just no bottom front. Got to get buffing, just been a steady 95+ degrees here for weeks and I end up dripping sweat on everything!! LOL!
I have the two stainless moldings next to the rear side windows (Challenger top door moldings) if you're interested. $50. for the pair, nice shape.
:o
Mopar Rules!!
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #8 on: August 21, 2002 - 10:03:46 AM »
:o
VERY interested in the moldings if these are the ones that go on the door...I think they are also called belt moldings.   Where do I send the check?
Offline badfish
« Reply #9 on: August 21, 2002 - 07:26:17 PM »
  I will take the windshield mouldings. I already have the bottom one. Where do I send the money???
Offline sixpackcuda
  • Six pack to go!!!
« Reply #10 on: August 22, 2002 - 11:43:39 PM »
Sorry for the delay.
Ok let me get some pics. The challenger door belt moldings are a 4 piece set and I have the ones (2) that go next to the back window behind the door. I don't have the ones on top of the door.
Contact me at:
russsnow@sixpackcuda.us
8)
Mopar Rules!!
Offline Rev-It-Up
  • Global Moderator
« Reply #11 on: August 23, 2002 - 12:59:53 AM »
Thanks for clearing up the molding question.  I need the ones that go on the door. :'(  Thanks anyway.
Offline 05srtcuda
« Reply #12 on: September 17, 2009 - 02:51:51 AM »
BY ANY CHANCE DO YOU HAVE A HEADLIGHT SWITCH?
Offline dutch
« Reply #13 on: September 17, 2009 - 03:03:44 AM »
 :clueless:  seller was last active in 2004....  :22yikes:    maybe you`d better try posting a wanted ad....
*** Bart ***
Offline 71Challenger426ci
« Reply #14 on: June 25, 2010 - 02:44:49 AM »
you got a grille??
WHAA!! YOU SAID PRO TOURING??
